2008 Ford E150 4.8L V8 4R75E Trans -247,500 miles - SHUTTING DOWN
- Trailman24
- Thank you received: 4
6 years 11 months ago #34840
by Trailman24
2008 Ford E150 4.8L V8 4R75E Trans -247,500 miles - SHUTTING DOWN was created by Trailman24
Driving along and transmission seems to go into Neutral , engine throttle will rev up and down then rengages tranny and dies.Was at dealer from April til November 2019. Replaced ECM, Throttle body, Mass Airflow Sensor. No changes. Codes: P061B, P1000, P1233, P2105, P2107, U0121, U0300. Normally can switch key off, back on , start and continue on til unit dies. Have a new engine wiring harness about to try. Dealer supposedly cleaned and checked all grounds. HELP !
- TheTechWhisperer
- Thank you received: 47
6 years 11 months ago #34849
by TheTechWhisperer
"You will always find the greatest fulfillment in life when you are operating in the gifts God gave you"- Dad
National Director of Technical Training & Mechanical Operations - Express Oil Change & Tire Engineers
ASE Master L1 Tech
BMW Master Tech
Ford FACT Advanced Electronics Instructor
Replied by TheTechWhisperer on topic 2008 Ford E150 4.8L V8 4R75E Trans -247,500 miles - SHUTTING DOWN
These are bad about coils in the early stages of failure that will backfeed voltage to the PCM and cause weird issues like this. I have had multiple cases of this after other shops threw PCM's at it and then gave up. The tricky thing is that it happens before the coil completely fails, so many times you won't have misfire codes. I use my scope w/ inductive pickup attachment to find them pretty quickly on Fords. Also check mode 6 and look at "$53" to see if any cylinders stand out
I would also double check the harness for the throttle near the EGR tube - they rub and short there. Haven't had the trans disengagement associated with this, but worth checking.
ASE Master L1 Tech
BMW Master Tech
The following user(s) said Thank You: Trailman24, aboudi.naddaf
- Trailman24
6 years 11 months ago #34882
by Trailman24
Replied by Trailman24 on topic 2008 Ford E150 4.6L V8 4R75E Trans -247,500 miles - SHUTTING DOWN
Installed new engine main wiring harness. Let sit overnight. Started engine ran about 30 seconds, then shut off. Repeated, same result. Started again and ran fine for trip of 30 miles, then shut off. Pulled to side of road, restarted, went to pull off and died again. Trip back home took forever. Might run 1 mile before shutting down, or 10 miles. Current codes: P1489, P060A, U0300, P2105. HEAD MECHANIC AT FORD DEALERSHIP IN FORSYTH SAID HE WAS UNABLE TO PROGRAM PCM. I DO NOT UNDERSTAND THIS. Is the only place to get the PCM programmed a Ford dealership ?
- Trailman24
6 years 11 months ago #34883
by Trailman24
Tranny did not act like it went into neutral at any time during shut downs this trip.
- Cheryl
- Thank you received: 215
6 years 11 months ago #34884
by Cheryl
Replied by Cheryl on topic 2008 Ford E150 4.6L V8 4R75E Trans -247,500 miles - SHUTTING DOWN
What are the code definitions? Is it an immediate shut down like the key was turned off or dying like it’s starving for fuel
- Trailman24
6 years 11 months ago #34885
by Trailman24
LIKE THE KEY WAS SHUT OFF.
U0300 INTERNAL CONTROL MODULE SOFTWARE INCOMPATIBILITY
P060A INTERNAL CONTROL MODULE MONITORING PROCESSOR
P2105 THROTTLE ACTUATOR CONTROL SYSTEM - FORCED ENGINE SHUTDOWN
P1489 PCV HEATER CONTROL CIRCUIT [NO ELECTRICAL CONNECTION BETWEEN PCV VALVE TO AIR INTAKE HOSE
- Cheryl
6 years 11 months ago #34886
by Cheryl
Sounds like you need a pcm but I’d do more testing before that. Does check engine light illuminate when it stalls out??
- Cheryl
6 years 11 months ago #34887
by Cheryl
If not the pcm Is not communicating at that time
Time to create page: 0.322 seconds
