High purge solenoid voltage spike
- Evanlip
PURGE SOLENOID CONTROL,electrical
These 2 codes
But the ECU Is controlling the purge i can see it from the scope with clear squarewave 12v - 0v
The solenoid is clicking as well
But what i noticed is it creates a very high voltage spike which over 50v, is that normal for this type of solenoid?
Will try to capture the waveform and post it here
- borntoroll
- Thank you received: 9
Voltage spikes are ok. 50v is not that much of a spike.Evanlip wrote: Hi,i have a question,i have checked a Audi TT purge solenoid valve on off waveform with scope,the trouble code keep on popping the PURGE SOLENOID CONTROL,activation
These 2 codes
- Evanlip
when i removed the canister i can hear the sound of the canister when i shake it,it sounds like the hand shaker musical instrument.
i ordered a genuine brand new and i did the same way,it doesn't sound like the old one.
so this give me a bit more confidence to put it into the car.
i brought it for few test drive,so far so good.no trouble codes so far.
but can someone explain this,why the computer trigger these 2 codes "IF" canister was really the cause?
thanks guys
- borntoroll
- Evanlip
what i do remember the description are
2 codes at the same time.
now the codes are gone.
so sorry bro
otherwise i will try to install the old canister and recheck again.
- borntoroll
- Evanlip
Made me no choice to look for other possibilities.
What do u think?
- borntoroll
- Evanlip
THe code will only come out after a few kilometers drive.
I will keep test driving the ca first,before i can call it a fixed
I've never worked on a TT, but I have seen other makes/models set purge codes due to EVAP leaks or faulty pressure sensors. In those cases, the PCM was commanding canister purge, and wasn't seeing a corresponding change in fuel tank pressure. It's silly fault detection logic, but that's how some are
- Evanlip
Thanks Tyler,im not sure about this too,hope i can give this car a fix.
Anyway your explanation is good and make sense.
Thanks
- Jackolope56
- Thank you received: 6
We cannot change the past or predict the future
