06 honda ridgeline 3.5L p2279 intake leak
- gilbert
- Thank you received: 15
6 years 5 months ago #34650
by gilbert
06 honda ridgeline 3.5L p2279 intake leak was created by gilbert
God bless you my brothers and sisters.
Hey I have a quick question I'm doing a smoke test on the truck and I have smoke coming from the egr valve. Question is is this normal?
Thank you.
Thank you.
- Cheryl
- Thank you received: 215
6 years 5 months ago #34652
by Cheryl
Replied by Cheryl on topic 06 honda ridgeline 3.5L p2279 intake leak
Fuel trims high? I’d spray brake clean around the leak looking at trims if they go negative I’d say it’s a leak. The old fords always leaked from the egr valve during smoke tests
The following user(s) said Thank You: Noah, gilbert
- gilbert
6 years 5 months ago #34654
by gilbert
Replied by gilbert on topic 06 honda ridgeline 3.5L p2279 intake leak
I'm not sure but I think I had -17 long term. I will have to check tomorrow.
- gilbert
6 years 5 months ago #34663
by gilbert
I'm not sure but I think I had -17 long term. I will have to check tomorrow. Ok it's tomorrow here are pics from freeze frame.
Thank you.
Thank you.
- Thank you received: 1116
6 years 5 months ago #34668
Replied by Noah on topic 06 honda ridgeline 3.5L p2279 intake leak
Hi Gilbert
I'm OK with some smoke from the EGR.
The following user(s) said Thank You: gilbert
- gilbert
6 years 5 months ago #34670
by gilbert
Thanks Noah with you that make 2. Today l found out that it is leaking from the vavle cover grommets to spark plug tube. I had the coils loose and started the truck and the coils popped out on 2 cylinder.
Thank you guy's for your help.
- Thank you received: 727
6 years 5 months ago #34671
After I first got a smoke machine, I replace a couple EGR valves (different vehicles) only to find the new ones leaking, too. I'm "OK" with a leaking EGR, now, too.
Replied by Chad on topic 06 honda ridgeline 3.5L p2279 intake leak
Noah wrote: Hi Gilbert
