Honda CR-V 2017 - P05AE fault code, Active shutter error
- forumoto
- Christ De KING
7 years 5 days ago #34424
by forumoto
Christ De Way Maker
Honda CR-V 2017 - P05AE fault code, Active shutter error was created by forumoto
this car has issue with CHECK LIGHT and the only code it produce is P05AE, related to active shutter grill... the sensors which ,move the flap are there, yet the code keep throwing, i have replace the sensors yet still... when key is turn on, here is a movement of the sensors, so i dont know what is happening
i need hlp
2017 Honda CRV
4 Cyliinder engine
Petrol.
America Spec
i need hlp
2017 Honda CRV
4 Cyliinder engine
Petrol.
America Spec
Christ De Way Maker
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
7 years 5 days ago #34426
by VegasJAK
Replied by VegasJAK on topic Honda CR-V 2017 - P05AE fault code, Active shutter error
the sensor activates the stepper motor which in turn moves the vents open and shut. the vents are behind the grill just in front of the radiator. if you're mechanically inclined you have to get to the stepper motor and see if its working by putting voltage directly to the stepper motor. either the stepper is not working or one or more of the vents are stuck in position.
- forumoto
- Christ De KING
7 years 5 days ago #34428
by forumoto
Christ De Way Maker
Replied by forumoto on topic Honda CR-V 2017 - P05AE fault code, Active shutter error
Thank you scannerJohn, I have check the stepper motors, they re all good. In fact power comes to the motors, and they swing when ignition is turn on, both motors but I wonder why this code keep coming up ...
Christ De Way Maker
- VegasJAK
7 years 5 days ago #34430
by VegasJAK
for my info... have you cleared the code after the repair then the code comes back
- forumoto
- Christ De KING
7 years 5 days ago #34437
by forumoto
Christ De Way Maker
Yes when I clear the code, turn the ignition off and then turn it on, then the code come back in about 30 seconds or sometimes less...
I also have C1870 code in the AWD module, any look up on this code , it is related to air fuel emission issue.
Christ De Way Maker
- VegasJAK
7 years 4 days ago #34453
by VegasJAK
not much data available on active shutter problems... the system is tied into the engine temp and I suspect maybe something in the speed control as the shutters open and shut with engine temp and speed of vehicle.
The PCM relies on voltage readings from each of the sensors to properly operate the shutters. Even though the stepper motors move the shutters, one or both may not be sending the proper voltage signal to the PCM. Engine temp is very critical but I not leaning in that direction as you have not mentioned an over heating problem. I'm thinking that one of the steppers is not giving the proper voltage signal. Can't come up with wiring diagrams, but the steppers should have a ground, power and signal wire. If you can, check the signal wire and note the signal voltage. Compare it to the second stepper. Both should give the same reading. You might as well check the power reference signal as well. Depending on the design, the reference voltage may not be 12v.
In any event, the reason the code returns is because the voltage signal is out of operating range, so the PCM throws the code. A bad or weak ground can cause voltage problems.
I'll keep trying to find a wiring diagram.
- forumoto
- Christ De KING
7 years 3 days ago #34485
by forumoto
Christ De Way Maker
Gotta buy the lower shutter grill and have it install, then will update this thread after the installation.
Thanks scannerJohn
Thanks scannerJohn
Christ De Way Maker
