03 Neon sxt 2.0 sohc automatic p0171
- 350boatracing
Fuel trims: With the car in park the fuel trims are normal. When I did the snap throttle a few times really fast I noticed the positive fuel trim maxed on maybe 1 out of 5 consistent snaps for a brief second.
In drive when I am going down the road the trims almost immediately max out around 32 or so and stay there.
I've never heard of trims looking mostly normal on snap throttle but consistently maxed out while driving. A garage I took it to said fuel pump but I have been betting against that.
- Thank you received: 1139
This is real good video that can help you determine if you are loosing fuel or if the MAF is misreporting by watching the upstream O2 sensor during a wide open throttle pull.
- cheryl hartkorn
- Thank you received: 130
- 350boatracing
- 350boatracing
Part of the problem for me also is that the neons use a reference voltage on the signal wires and i'm not familiar with what range of numbers I should be in for stoichiometry.
Good point!cheryl hartkorn wrote: I didn't think dodge used maf sensors.
I kind of remembered that as I was typing out another post, lol. Thanks for pointing that out.
Does it idle normal? I ask because a MAP engine with a vacuum leak would show normal trim numbers at idle. It would interpret the increased manifold pressure as a load condition and increase injector pulse width to keep up with the perceived demand. The result would be higher than normal idle.
- 350boatracing
When the car warms up the idle sits around 744 and usually sinks to 500 at red lights but I think that's another issue all together.
350boatracing wrote: But the video may still be helpful. I was wondering before how to tell if i'm running rich or lean at wot (because I know the pcm ignores 02 readings at this point ) but I obviously never thought too hard about just watching my 02s at wot.
During your WOT run, watch for the upstream o2's to stay above 800mv right up to the shift into second gear.
If you're not comfortable with the o2 data, you could try the same thing with a fuel pressure gauge taped to the windshield.
I've done that more than few times.. :whistle:
- 350boatracing
So at 50, you're already out of range, then dropping another 1 or 2 psi on snap...
Looks like a probable cause of the p0171.
- 350boatracing
- 350boatracing
- 350boatracing
- 350boatracing
- 350boatracing
- matt.white
- Thank you received: 29
I also saw the long term trims go to 32% in the first set of pictures, BUT that was during open loop operation. I do like that the O2 signal isn't pegged lean, at least while you were testing it. Could be going dead at other times
If you're willing, maybe try taking another capture? Narrow down your PIDs to engine speed, MAP voltage, both O2's, TPS voltage, and loop status. Wind out first and second gears at WOT. Highway on-ramps are great for this.
Then, save the file on your Modis. That way, you can use ShopStream Connect to easily review the data later, OR send it to us! Most members around here that have a Snap-On scanner also use ShopStream to manage data captures like this.
- 350boatracing
- matt.white
- 350boatracing
