Engine running, no acceleration.
  • Dokteur oto
  • Dokteur oto's Avatar Topic Author
7 years 1 month ago #33652 by Dokteur oto
Engine running, no acceleration. was created by Dokteur oto
Hi everyone. I'm actually working on a Lincoln Town Car 2011 with a V8 engine/ 4.6L. When the key is in on position the throttle motor makes a weird noise, and the engine will not even crank. To start the car I have to disconnect the throttle motor. Now, when the engine is running there's no acceleration. It's stuck in limping mode. I thought it could be a problem within the pcm where the TACM could be either shorted to power or to ground. But it's not the case. I replaced the pcm, the problem is still there. The TPS operates properly because, I can see on my bd scan tool live data from the tps on how it reacts when the gas pedal is depressed. However, there's a few DTCs such as : P2100, P2104, P2107, P2110. I could never find anything abnormal in term of short circuit like those codes suggest.
Please any help will be appreciated. Thanks to everyone.
7 years 1 month ago #33654 by ptebo1
Replied by ptebo1 on topic Engine running, no acceleration.
p2100 dtc is most likely setting the other dtc`s. Ford has a reputation for bad throttle bodies. p2100 indicates a motor circuit fault. Ford advises to measure the resistance of the motor circuit @ the throttle body. The spec given is odd but Ford gives a resistance spec of 1-900 ohms. Otherwise they have you doing your typical resistance checks from the throttle body connector to the ecm connector. Let me know if you need connector pin-outs or a wiring diagram. could you post a couple of pictures of throttle body vs app pids, one @ closed throttle and one @ wide open throttle.
