[FIXED] 07 Cadillac Escalade crank no start
  • Matts Auto
  • Matts Auto's Avatar Topic Author
7 years 1 month ago #33419 by Matts Auto
07 Cadillac Escalade crank no start was created by Matts Auto
Long story short found no power koeo to injector a & injector b fuses (plus some others). Did lots of testing & found Ecm not commanding pwr/trn relay. Anyone recommend an aftermarket company for a pre-programmed Ecm ?
7 years 1 month ago #33423 by John Curtis
Replied by John Curtis on topic 07 Cadillac Escalade crank no start
I know it’s not exactly what you’re asking for however, if you have a capable scan tool, I would suggest grabbing a used ECM from a salvage yard and do an immobilizer match and rewrite the VIN.
  • Matts Auto
7 years 1 month ago #33426 by Matts Auto
Replied by Matts Auto on topic 07 Cadillac Escalade crank no start
I've never replaced with used before but in this case would be ideal. Thanks for the suggestion
  • Matts Auto
7 years 1 month ago #33435 by Matts Auto
Customer decided to go with a preprogrammed unit from the internet that they ordered. Hope that doesn't spell trouble for me!!!!
7 years 1 month ago #33441 by Tyler
Replied by Tyler on topic 07 Cadillac Escalade crank no start
Following along. :) Genuinely interested to see how the internet special PCM turns out.
You're sure the PCM just wasn't commanding the powertrain relay? Cool! :silly: I've seen very similar symptoms on other GM products, tracked to failed fuse box connections.
  • Matts Auto
7 years 1 month ago #33445 by Matts Auto
I tested at pcm the relay command (none). I can activate relay with test light & make vehicle run.
7 years 1 month ago #33446 by Tyler
Matts Auto wrote: I tested at pcm the relay command (none). I can activate relay with test light & make vehicle run.
Good enough for me. :)
  • Matts Auto
7 years 1 month ago #33528 by Matts Auto
Received pcm today, customer had purchased from flashmasters.com out of ohio. Replaced pcm, performed security relearn & started right up. Then performed ckp variation relearn, cleared codes & test drove while checking data & everything works fine. I have to admit i was a little skepticle about the internet purchase but fortunately all is good. We can call this one FIXED!!
