02 Dakota 4.7
- Slim4212
7 years 2 months ago #33101
by Slim4212
02 Dakota 4.7 was created by Slim4212
I have a problem with my 2002 Dodge Dakota 4.7. I keep getting P0172 rich on bank one code. I also have missfire on cylinders one and eight. My fuel trims are -30 to -33. I can not find any vaccuum leaks. Upstream and downstream O2's have been replaced. TPS, IAC, coolant temp sensor, and cam sensor have been replaced. The milk is fine seems to get worse the as the engine gets up to operating temp and around the 45 to 55 mph range. The miss will intermittently cause the truck to jerk. My spark plugs on cylinders one and eight are black and chalky. All the other plugs are white and chalky. I have been chasing this problem for about 2 1/2 months now and can not figure this out. Can someone please help me before I completely loose my mind?
- cj1
- Thank you received: 12
7 years 2 months ago #33102
by cj1
Replied by cj1 on topic 02 Dakota 4.7
"My spark plugs on cylinders one and eight are black and chalky"
Leaky fuel injectors?
- Cheryl
- Thank you received: 215
7 years 2 months ago #33110
by Cheryl
Replied by Cheryl on topic 02 Dakota 4.7
I’d suspect injectors. Do you have a fuel pressure gauge? Those should be easy to check pressure on if I remember they have a schrader valve on the fuel rail check and see if pressure bleeds off
- Slim4212
7 years 2 months ago #33125
by Slim4212
Replied by Slim4212 on topic 02 Dakota 4.7
Pressure bleeds off over 10-15 min. Is this normal or should it continue to hold pressure.
- Slim4212
7 years 2 months ago #33126
by Slim4212
Not sure bu I will get it checked
- Cheryl
7 years 2 months ago #33127
by Cheryl
How much does it bleed down in that time frame??
- Slim4212
7 years 2 months ago #33128
by Slim4212
Cheryl, yes it does have the Schrader valve. How long should it hold continues pressure. It seems to drop a little after 10-15 min.
- Slim4212
7 years 2 months ago #33129
by Slim4212
About 8-12 psi
- Cheryl
7 years 2 months ago #33131
by Cheryl
I’d suspect leaking injectors
- Slim4212
7 years 2 months ago #33132
by Slim4212
Ok. I will pick a couple up at the parts store. Would you recommend getting all eight or just replace the ones in the two cylinders that have the missfire?
Time to create page: 0.345 seconds
