Sudden Engine Stop
  • Loney911
  • Loney911's Avatar Topic Author
7 years 2 months ago #33082 by Loney911
Sudden Engine Stop was created by Loney911
Mazada Demeo 2012
Engine is sudden stop while on drive
I have checked it on different speed
*no fault code
*no fault indicator light on IClusture
*can start engine again without any issue
Surprising point is it won’t happen in cold weather like rainy day
Need a solution for this
Thanks
7 years 2 months ago #33087 by Gazmendhajra
Replied by Gazmendhajra on topic Sudden Engine Stop
It might be a torque converter if only in drive , see if ur brake switch is working maybe it is not disengaging
The following user(s) said Thank You: Loney911, D.racine94
  • Loney911
7 years 2 months ago #33096 by Loney911
Replied by Loney911 on topic Sudden Engine Stop
Gazmendhajra wrote: It might be a torque converter if only in drive , see if ur brake switch is working maybe it is not disengaging
Brake switch is working
7 years 1 month ago #33540 by John Curtis
Replied by John Curtis on topic Sudden Engine Stop
Is it automatic or manual?
Have you checked the basics?
There is a TSB for MAF problems.
Check the following?
EGR function?
Throttle body?
IAC?
Do you have access to live data?
7 years 1 month ago #33628 by Alex Ace Auto
Replied by Alex Ace Auto on topic Sudden Engine Stop
Help us help you, We need more data.
What have you done?
  • Loney911
7 years 1 month ago #33645 by Loney911
Alex Ace Auto wrote: Help us help you, We need more data.
What have you done?
Just clean the throttle body
