crankshaft reading odd while cranking
- Carstuff
- Thank you received: 19
7 years 2 months ago #33040
by Carstuff
crankshaft reading odd while cranking was created by Carstuff
How could a crankshaft reading be erratic while cranking but good while running?
in the video is a slow down zoomed in of the crankshaft sensor during cranking.
signal begans 10 seconds in.
7 years 2 months ago - 7 years 2 months ago #33041
Replied by Andy.MacFadyen on topic crankshaft reading odd while cranking
Depends on the manufacturer and engine model type but a lot of engines will run quite happily on the cam sensor alone --- with others it is the otherway around. Usual clue is a slightly extended cranking time.
Last edit: 7 years 2 months ago by Andy.MacFadyen.
- Carstuff
7 years 2 months ago #33052
by Carstuff
Replied by Carstuff on topic crankshaft reading odd while cranking
The wave form while running is ok when comparing it to the snapon image. Its only during cranking its like the second hump is erratic during cranking
7 years 2 months ago #33064
Replied by Chad on topic crankshaft reading odd while cranking
Variable Reluctance Sensors produce an AC sine wave. The amplitude of the signal is affected by different factors. Rotational speed being one of them. The faster the reluctor wheel turns, the higher the amplitude will be. The Air gap between the sensor and reluctor is another factor that will affect amplitude.
7 years 2 months ago #33066
With magneto resistive crank sensors the engine computer looks at the signal with the DC filtered out, so once you intially connect up the scope and get a first look switch the scope to AC and you will get a cleaner easier to read trace on the scope.
