Brake pressure modulator valve assembly replacement
  • autojoe
7 years 2 months ago #32947 by autojoe
2006 chevy Tahoe 5.3 flex fuel brake pressure modulator valve assembly leaking rusted out. Like 5 different part numbers on alldata. With and without luxury edition. With jl4 without jl4 which is active brake control. The truck has traction control. Is there a way to look at rpo codes and which ones to find out information to get correct part number? Also have to bleed all wheels and master cylinder and use a scan tool to do an automated bleed on new brake pressure modulator valve assembly. Thanks for any input.
7 years 2 months ago #32951 by Tyler
On your truck, the RPO codes are gonna be in the glove box.
d354nuoz4t18d4.cloudfront.net/b0a0b93e06...es.pdf?cb=1566224514
  • autojoe
7 years 2 months ago #32958 by autojoe
Thanks Tyler how do I find out in that long list of rpo codes for the brake pressure modulator valve assembly?
7 years 2 months ago #32962 by Tyler
Checking RockAuto, it looks like ACDelco #19149234 is for RWD without Active Brake Control, or RPO JL4. #19122463 is for trucks with JL4, transfer case RPO's NP8 or NR3, or tire option QSS.
Does your truck have JL4, or JL0?
  • autojoe
7 years 2 months ago #32963 by autojoe
It has traction control if it helps.
