Vauxhall Z16SE
9 years 9 months ago #4261 by Wolos
Vauxhall Z16SE was created by Wolos
Hi,
Could you please help me with the following codes.
Fault codes
Fault code Code type Definition
P0340 Stored Camshaft Position Sensor A Circuit Malfunction (Bank 1 or
Single Sensor)
P0460 Stored Multiple definitions available:
Fuel Level Sensor Circuit Malfunction
Fuel Level Sensor A Circuit Fuel Level Sensor Low Voltage Fuel Tank Level Open Circuit
P0220 Pending Throttle/Pedal Position Sensor/Switch B Circuit
Malfunction
P1550 Stared Electronic throttle system (ETS) - in emergency mode
P0120 Pending Throttle/Pedal Position Sensor/Switch A Circuit
P0220 Stored Throttle/Pedal Position Sensor/Switch B Circuit
Malfunction
P1550 Pending Electronic throttle system (ETS) - in emergency mode
Background info:
Camshaft Position Sensor has been exchanged.However code still shows up. Noticed that one of the pins was not straight. Corrected now.
I checked TPS (electric type) 8 pins. I got the following results measured on the disconnected plug -on front of the plug, ignition on, ground on the engine, - 1st signal -0.33V, 2nd signal 4.28. I was not sure about the rest of the pins but showing: -.0.45V, 4.21V, -0.45V, 4.29V, 11.42V, 11.78 V.
Thanks
Mariusz
9 years 9 months ago #4262 by steve
Replied by steve on topic Vauxhall Z16SE
What year and model is this?
On the face of it with them codes it looks like a classic Vauxhall ecu fault
But first make sure your meter is connected to a good ground, go to the battery instead of the engine
Check the camshaft sensor, throttle position sensor and accelerator pedal sensor for the 5v ref
