[FIXED] 2000 Chrysler T&C Starting Problem
- popoften
- Thank you received: 22
I suspect the problem is the starter motor itself. The fact that turning the key off when the engine was running and the starter would not disengage but the fuel did cut off and shut down the engine indicates to me that the ignition switch is probably OK. The fact that I pulled the starter relay and the starter still would not disengage indicates to me that the relay is OK ( I bench-tested the relay and it is apparently OK).
I can touch the negative cable to the battery with key off and relay out and starter cranks.
Based on the attached Mitchell circuit diagram, I'd say at this point we call a bad starter because the last remaining possibility, at least that I can think of, is that the solenoid is stuck closed meaning power flows to the starter as long as battery is connected.
Do you guys concur, or have I possibly missed something?
- popoften
- Ro-longo
- North Salt Lake, Utah
- Thank you received: 43
- cheryl hartkorn
- Thank you received: 130
popoften wrote: Come to think of it, one other possible thing to eliminate is the brown wire to starter solenoid being shorted to power. I doubt this though, because when I touch the neg batt cable to the neg batt post all I hear is the engine cranking; I do not hear the starter re-engaging the flywheel. Still an easy check once I am under the car so I will go ahead and check that.
You read my mind! This is the last thing I'd do before sticking a fork in the starter.
I have seen this symptom before - when another tech was installing a starter, and installed the solenoid wire in such a way that it always touched the B+ post. Thus, when he went to reconnect the battery, it cranked! :lol:
- FlyinHawaiian
- Thank you received: 3
Tyler wrote: I have seen this symptom before - when another tech was installing a starter, and installed the solenoid wire in such a way that it always touched the B+ post. Thus, when he went to reconnect the battery, it cranked! :lol:
If that happened to me, it would freak me out :ohmy:
- popoften
It seems to me, then, what we have here is a starter solenoid stuck in the closed position, and since the solenoid is internal to the starter I am looking at replacing the starter.
Do you guys concur?
- popoften
Thanks again, guys!
~pop
- Thank you received: 1138
- popoften
A postscript -- once I had the starter out I thought I would see if it would crank by just hooking up the battery cable to the main post of the starter and to battery positive, and from battery negative to the starter case. I figured it would crank just as it had when it was still installed in the truck. For some reason, it didn't.
I did not give it any more of a post mortem than that. I am just glad the new one works and the old one went back as a core return.
I guess it's good you didn't go tapping on the starter during diagnosis - the problem might have gone away, and you'd be left scratching your head :lol:
