P2195 and p2196 codes popped up recently on 2003 Explorer 4.0
  • Floridaexplorer
  • Floridaexplorer's Avatar Topic Author
7 years 2 months ago #32751 by Floridaexplorer
I tried looking for an arc last night and spraying water with water bottle.
7 years 2 months ago #32752 by Andy_
Let me look online later for the manual for your scan tool. I want to see if it says anywhere if your tool can access mode 06. I would guess it can since it's part of the generic side. If so, we should be able to see what cylinder has misfires, if any.
The following user(s) said Thank You: Floridaexplorer
  • Floridaexplorer
7 years 2 months ago #32753 by Floridaexplorer
I called innova manufacturer was told yes when I hook up it only has o2, obd and evap for mode6
  • Floridaexplorer
7 years 2 months ago - 7 years 2 months ago #32759 by Floridaexplorer
My new mpg today was 14 (not 8 mpg like last time and I had some idle time in that)
After replacing one o2 sensor and fuel filter
Last edit: 7 years 2 months ago by Floridaexplorer.
  • Floridaexplorer
7 years 2 months ago #32762 by Floridaexplorer
What about video I posted? I would go to each o2 then gun it. At end I scrolled while idling.
7 years 2 months ago #32782 by Andy_
Honestly, I haven't had time to watch the video. I'm swamped at work.
Are you still getting the p2195? If not, that's a good thing and we can move on to whatever other problem you have.
  • Floridaexplorer
7 years 2 months ago #32790 by Floridaexplorer
Cleared code hasn't returned yet, last time took a few weeks to return.
7 years 2 months ago #32804 by Andy_
One other question. I know you said you replaced the muffler. You did mean the muffler and not the cat, correct? The reason I ask is because P2195 can sometimes be caused be exhaust leaks near the sensor. I've seen other lean codes (P0171,174) on Fords that have leaking exhaust manifolds. It's not always a true 'lean' condition, just what is perceived as lean.
  • Floridaexplorer
7 years 2 months ago #32806 by Floridaexplorer
Yes replaced with Thrush turbo muffler from AutoZone. Maybe the o2 sensor fixed. And I dont fully understand live data. I though the downstream showed 0 a time or two while running s1b1 after I replaced the upstream s1b1 (video)
7 years 2 months ago #32809 by Andy_
Ok, so it looks like you may have your code fixed.
What drivability symptoms are you still having? Do you still feel a misfire? Can you describe what it feels like, when it happens, rpm range, speed, etc?
Don't feel bad about not fully understanding data. It takes a lot of practice. Keep studying data after you get this problem fixed. It's hard to learn when your under the gun. Start learning what good data is to help you know what's not good.
  • Floridaexplorer
7 years 2 months ago #32851 by Floridaexplorer
Like a bucking or jerking.
Is replacing spark plugs after 16 to 17000 miles too soon? Today was 15 mpg average.
Thinking about replacing other upstream o2 sensor and spark plugs again after 16000 miles. I havent messed with rotor. Changed oligs and wores last year about 16000 miles ago.
7 years 2 months ago #32856 by Andy_
If you didn't use the OE Motorcraft plug, then I would put those in. If you did use OE plugs, then leave them alone.
Unless your fuel trims dictate it or you set a code, don't change the O2 sensor. \
What you're describing sounds like an ignition misfire, which is really why I was hoping your scan tool had Mode 06 data. It doesn't, so that makes finding the culprit cylinder a bit harder, and your tool doesn't have the power balance test either. You don't have a scope do you?
  • Floridaexplorer
7 years 2 months ago #32895 by Floridaexplorer
Sorry notifications are late to me. I just replaced drive side with Bosch double platinum plugs. Autozone and Ford said motorcraft double platinum but double platinum not an option in motorcraft. I just came inside from installing 3 left driver side cylinder 4,5,and 6 with Bosch.
This morning I installed flex exhaust pipe to connect my muffler (new) back to the rear tailpipe so its quieter.
I plan to do plugs 1, 2 and 3 later or tomorrow and replace wires again tomorrow. If it's not running great after this I will shoot cat converter with an infrared thermometer laser and if that goes good I will be leaning towards maybe it's the transmission
I think you said if not motorcraft I should leave plugs alone but I didn't get the notification. I'm labeling the old plugs so pics of old plugs can be likely tomorrow.
  • Floridaexplorer
7 years 2 months ago #32896 by Floridaexplorer
As stated before I replaced bank 1 upstream o2 sensor the other day and my mog went from 8 to 13 to 15 to 16 thusfar.
  • Floridaexplorer
7 years 2 months ago #32902 by Floridaexplorer
Just shy of 17000 miles
  • Floridaexplorer
7 years 2 months ago #32939 by Floridaexplorer
All 6 plugs new again. Yesterday I almost averaged 17 mpg.
Still jerk or bucking, transmission or torque converter crossed my mind. On Google some one else suspected tc and it was cool pack. I asked Autozone yesterday and was told I have a single coil pack feeding all 6 cylinders, no rotor.
Thinking about buying mass airflow sensor cleaner next. I replaced wires last year but have not this week yet.
  • Floridaexplorer
7 years 2 months ago #32978 by Floridaexplorer
Replaced coil pack and air filter was still bucking. Then I replaced wires and cleaned mass air flow sensor and driving home tonight It didn't buck so hoping finally fixed it.
