2017 Ford f150 XL rear brakes wear horribly uneven
  • Mitchroberson
  • Mitchroberson's Avatar Topic Author
7 years 3 months ago #31572 by Mitchroberson
Ok so this is a one owner truck. With only 50k miles. The rear passenger side brake pad. The one on the inside were all the way down and tore up the rotor. The outside pad was same thickness as new pad.
And drivers side pads were evenly worn but again just small amount compared to new pads.
Has any heard of this I have been told it is because of traction control. But not sure I believe it.
7 years 3 months ago #31575 by PDM
The caliper pins are seized in the bracket. The caliper should move somewhat freely in the bracket. Check out South Main Auto Youtube channel. He has a lot of great brake job videos
  • Mitchroberson
7 years 3 months ago #31581 by Mitchroberson
Replied by Mitchroberson on topic Re:2017 Ford f150 XL rear brakes wear horribly uneven
Pins came right out. Looked great and moved with out issue. I checked the electric break motor and it seems to work fine. So not sure what caused it yet.
7 years 3 months ago #31588 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 2017 Ford f150 XL rear brakes wear horribly uneven
While it usually the caliper pins it is more than possible the pad it self is jamming in its' guide slots.
7 years 3 months ago #31591 by PDM
Yep. Did the pads come out easily? You shouldn’t have to force them out.
7 years 3 months ago #31593 by Tyler
Did the piston compress easily after retracting the parking brake motor?
