P0400 due to Faulty ECM?
  • Genes1s
  • Genes1s's Avatar Topic Author
7 years 4 months ago - 7 years 4 months ago #31224 by Genes1s
P0400 due to Faulty ECM? was created by Genes1s
I have 2000 Nissan Maxima that I have been troubleshooting for P0400 issue.
Little background.
Last November, I did a bunch of work on the engine and when I put it back together, I had P0403 and P0505. The P0505 was resolved after idle learning and soon after that the P0403 was resolved due to connection wire harness issue ( I could wiggle the wire harness and I would get intermittent connectivity)
Fast forward 2 weeks ago, I had P0403 again and I began to think that I have connectivity issue again eventhough my connectivity testing was all good. This time I re-did the both ends of the connectors on the EGR selenoid just for the piece of mind. Put it back together, and the P0403 had been l gone but now I have been getting P0400, which is Insufficient EGR flow. I have reset, took it apart and secured all wire harness connection and the codes came back after 20-50 miles of driving. This EGR system is electronically controlled, no vacuum lines. The plunger at EGR opening is pulsed up and down by the steeper motor per ECM command.
So far I confirm:
1. No exhaust leak.
2. Harness connectivity between ECM and EGR and EGR temp sensor are good.
3. Stepper Motor is working. Resistance is per spec and the motor steps with ignition on when connected to the IACV connector
4. EGR Temp is working. Tested with boiling water and VOM.
5. Battery is good.
6. Passages are clean and clear.
The one test that was off was the the signal from the ECM at Idle. See below diagram.
It says I should have 0.1-14V at idle speed on those terminals coming off the ECM. Terminal # 9 was 0.14V with no change when RPM was revved. Terminal # 10 had 0.02V at idle but jumped up to 0.1V when revved. Terminal #18 & 19 were 0.00V both at idle and revved. What do you call these signals? the voltage reference? why is it 0.1 - 14V though instead of commonly 5V.
Based on trouble shooting above, do I need new ECM? What other test to isolate this possibility. I was thinking about back probing the connector while it is plugged in and monitor the voltage changes under expected EGR actuation based on engine load and speed, but what that mean is I need to O-scope, which I don't have. Is there a decent troubleshooting OBD 2 that can do bidirectional test and show these feedback that doesn't cost as much as the car itself?
The car runs flawless other than the P0400 code which prevents it from passing the SMOG. No weird idles, nothing, just P0400.
Thanks for the help.
Last edit: 7 years 4 months ago by Genes1s.
7 years 4 months ago #31228 by jreardon
Replied by jreardon on topic P0400 due to Faulty ECM?
I would call them ground side control wires that get pulsed by the ECM. Assuming EGR relay is energized you will have 14v (assuming alternator working), at each of the 4 wires going to the ECM. When the ECMs wants to move the EGR valve (which should NOT happen at idle) the control wires will drop low, if using a slow DVOM, but really it's just a really fast pulsed ground provided by ECM.
Rig up a test light that's connected to battery positive, taped to your dashboard. The other end would be connected to one of the control wires. If the ECM driver is good, the light should turn on when EGR is commanded by appropriate driving condition. Test all 4 control wires this way. But really, find someone with a bidirectional scanner.
If one light or more fails to light up you might have to consider that a shorted coil inside the EGR took out ECM driver or maybe an intermittent short to power near control wires cooked the driver.
  • Genes1s
7 years 4 months ago #31235 by Genes1s
Replied by Genes1s on topic P0400 due to Faulty ECM?
[quote="j
If one light or more fails to light up you might have to consider that a shorted coil inside the EGR took out ECM driver or maybe an intermittent short to power near control wires cooked the driver.[/quote]
Do you think there is still a chance that the EGR has shorted even the resistant measured to spec?
So to test the ECM functionality, is probably best to get bi-directional scanner.
Thank you for your insight.
7 years 4 months ago - 7 years 4 months ago #31249 by jreardon
Hey wait a minute that relay is controlling more than just the EGR power! It also powers the ignition coils and you had the car running when you took those readings at the ECM. I mistakenly took those voltage readings as meaning nothing as my mind was thinking the relay must have been off! Let me revise my reply to you.
Those low numbers indicate the ECM is indeed grounding those control wires. Can you check them with a test light connected to battery positive at the ECM again with the engine running. That 0V reading concerns me, I hope that wire isn't open.
That 0V reading indicates either a shorted control wire, or an open wire. Unplug the ECM connector and test those wires for a short to ground, with your test light connected to battery positive.
Last edit: 7 years 4 months ago by jreardon.
  • Genes1s
7 years 4 months ago - 7 years 4 months ago #31273 by Genes1s
So, while the engine is idling, I disconnected the EGR plug and using test light connected at positive battery, I got Terminal # 9 lit up green and the 10,18, and 19 only dimly lit.
Terminal # 9
Terminal 10, 18, 19
So I don't think its open since the green LED lit up (circuit is close to ground). It indicates what my VOM did which is higher voltage in Terminal #9
For Short to ground test, I unplugged the ECM connector and probe the 4 terminals at the EGR connector with test light connected to the positive battery. no green light, which mean no short to ground either.
This basically proof that the harness have no short to ground condition and the first test proof that it's not open either, right??
Rather than going to a dealer or repair shop, I would rather spend the money to invest on the bi-directional scanner. Any suggestion...
Last edit: 7 years 3 months ago by Genes1s.
7 years 3 months ago #31276 by jreardon
Seems like this is not a hard fault. If you leave the EGR harness disconnected, does it throw a code immediately? Is it this code p0400?
7 years 3 months ago #31279 by jreardon
Yup. Did you shake the wire around just for good measure? This test doesn't rule out high resistance in the wire though, from heat. Maybe the coils inside the EGR valve fail under heat but ohms out good when it's nice and cold, you never know...
7 years 3 months ago #31281 by jreardon
Mr. Danner tests a similar 6 wire stepper IAC in this video in case you have not seen it:
The following user(s) said Thank You: Genes1s
  • Genes1s
7 years 3 months ago #31290 by Genes1s
I didn’t but will do. The EGR selenoid was in working condition and it moves and stepped when I plug it in with the IACV connector (same type of stepper motor bur smaller).
  • Genes1s
7 years 3 months ago #31304 by Genes1s
I have not back probed the connector while running. I did get 12 volt at terminal #2 and #5.
I’m going to pay Indy shop to trouble shoot it with bidirectional scanner, since everything else looks OK to me.
  • Genes1s
7 years 3 months ago #31306 by Genes1s
jreardon wrote: Mr. Danner tests a similar 6 wire stepper IAC in this video in case you have not seen it:
This is what I need to do . It's going to be challenging since the EGR connector is tucked underneath TB. I might have to rig up special wire to back probe the connector and do this test. This test is it....
Thank you for showing this, it totally makes sense now..
7 years 3 months ago #31311 by jreardon
Just re-reading everything and just want to ask if you load tested the control wires with a substituted load? Just looking at a single coil resistance, it's 24 ohms i think, and assuming 14 volts with car running, each control wire should be able to handle up to 583mA of current flow. I see in pictures you're using a led test light and those don't take much mA to light. I also read you did repair jobs on those wires if I'm not mistaken. Also check the two red power feeds, which are fused protected by 15A fuse, if they can handle at least 2.3 Amps.
  • Genes1s
7 years 3 months ago #31312 by Genes1s
I'll try these. The one thing for sure is that the EGR actuator it self is working just fine. The IACV actuator is similar and have the same connector. I swap the EGR to the IACV connector and the EGR actuators cycles fine, while the IACV didn't cycle.
7 years 3 months ago - 7 years 3 months ago #31314 by jreardon
Looking at IACV resistance, it IS indeed the same as the EGR resistance. IACV not moving indicates bad ECM, bad wire, or maybe IACV doesn't work with control signals MEANT for an EGR valve (I don't know lol).
I would be fine with a 1 amp light, it doesn't have to be exact by the way. Just hold it for a few seconds and move on to next wire.
Some pictures for help visualize the load test.
Last edit: 7 years 3 months ago by jreardon.
7 years 3 months ago - 7 years 3 months ago #31315 by jreardon
duplicate post
Last edit: 7 years 3 months ago by jreardon. Reason: duplicate post
  • Genes1s
7 years 3 months ago #31444 by Genes1s
Genes1s wrote: I have not back probed the connector while running. I did get 12 volt at terminal #2 and #5.
So with the bidirectional scanner, the shop was able to energize the EGR. Their conclusion was that the passages to the intake was clogged. Told them that I cleaned it real good and they insisted that it wasn’t clean enough. I asked if my ECM was ok and they said yes. I really doubt that the passages were clogged, I used wire brush attach to drill and it was all cleared with garden hose also.
7 years 3 months ago #31449 by jreardon
Dave: [after checking on a unit HAL reported as nearing failure] Well HAL, I'm damned if I can find anything wrong with it.
HAL: Yes, it's puzzling. I don't think I've ever seen anything quite like this before. I would recommend that we put the unit back in operation and let it fail. It should then be a simple matter to track down the cause. -2001: A Space Odyssey
  • Genes1s
7 years 3 months ago - 7 years 3 months ago #31757 by Genes1s
Finally had a chance to rig up test wires for backprobing the EGR connectors. It's such a tight space on there that I'm not comfortable using T pin to probe the back connector. I ended up splicing the connector with splice connector and running all 4 signal wires out. Signal wire are # 1, 3, 4, and 6. # 2 and # 5 are 12 V at.
Wit the engine running, I measured V across between each terminal and ground. Terminal #4 & 6 started at about 14V at idle then went down as I revved the engine.
With the engine off, I cycled the ignition on/off and got the same reading pattern as above. # 3 seemed to stay dead, while #4 and #6 behaved similarly.
It looks to me that terminal # 3 could be the issue? I guess the next step is using test light to check for open coil on the selenoid, or short to ground on the harness or ECM
  • Genes1s
7 years 3 months ago #31763 by Genes1s
Here is all 4 terminals at idles.
# 3 was flat lined....
  • Genes1s
7 years 3 months ago - 7 years 3 months ago #31766 by Genes1s
Here is the testing on all signals with ignition on and off cycles.
Here is the summary matrix
I'm not too familiar with how the stepper motor being energized.
#6 flickered a little when the ignition was turned on/off, almost to non existent but its there.
Time to create page: 0.389 seconds
