2006 Cadillac dts battery drain
- Betterway52
Fuse 32 in the rear fuse box which is under the rear seat supplies the heated rear seat module, it can draw around 4 amps if it doen't go to sleep.
Having a true current draw value, 45 minutes after shutting/locking all doors will give you a much better idea of the problem you're chasing.
- Crombie
- Thank you received: 3
Using a fuse breakout connector is also a good method but be aware that is very easy to blow the fuse in your multimeter as they are only rated to 10 amps.
I don't recommemd "Fuse Buddy" type meters I bought a pair and wasn't impressed by the wiring.
My preffered method is to use a DC current clamp meter -- I have a fairly low cost low range one specfically for this type of job. CEM DT-337 AC/DC Measurement Digital Multimeter Clamp Meter Tester
- Betterway52
- Betterway52
Betterway52 wrote: Ammeter or low amp probe? Same reading?
I have more confidence in an ammeter for accuracy, but feel free to use what you have available!
I notice as I connect my can test box the pin 1 on dlc continues to flash saying circuit is still active hours into everything should be off. Will have more info later today.
Well isn't that interesting. :huh: That'd be a low speed LAN, I believe. Can't tell what's on that network without a wiring diagram.
- Betterway52
Betterway52 wrote: I was not using the sensor as a guide just the pid caught my attention. So I mentioned it.
Apologies! I meant no insult.
- Betterway52
- Desmond6004
If you have an oscilloscope my method is to put a coil of wire in series with battery ground and measure the voltage drop across it with the scope. Disconnect battery ground, place the wire from battery negative to ground and measure voltage drop from the battery post to chassis ground.Betterway52 wrote: I have plenty of tools. I will use the ammeter and also put the low amp probe on the scope and measure it that way also.
Then I use a small accurate clamp meter to see what the voltage drop equates to. Some people use a 1 ohm resistor then 1v on the scope is 1 amp - but if the current draw is quite high the voltage drop gets too low for some systems to work properly - which is why I prefer a roll of thin wire.
Then I leave the scope on 20000 second recorder and watch the voltage change over time.
Before doing any of that I will have done a full system scan to check for faults. After an hour of watching the scope I'll do another full system scan with the ignition still off - then I find out what modules are still awake and check their live data to see if there is anything out of place - a Porsche once had "glove box" marked as "open" when it was actually closed, which kept 5 modules awake.
- Desmond6004
- Betterway52
How much did the draw end up being? Did the battery current sensor more or less agree?
Did pin 1 at the DLC ever shut up after the repair?
- Betterway52
