Trouble setting base ignition timing
  • Crombie
  • Crombie's Avatar Topic Author
7 years 4 months ago #30949 by Crombie
Trouble setting base ignition timing was created by Crombie
Hello, new to the website. Thanks Paul i did receive your reply it was in another email folder
I have a Honda CRX 1989 with a B16A vtec engine. I have the distributor all the way to retarded and Im still slightly advanced for base timing. I do have a slightly high idle, but if I remove the IACV connector it drops to about 700rpm, the base timing is very close there, but the distributor should be in a middle position, i have tried 2 different PCM's, since i have them, changed the coolant temperature sensor as I rebuilt most of the engine. The cams and crank are in time. i have checked cam and crank timing 4 times. I have used 2 different distributors, the 1st one was Honda but it was backfiring the bearing was gone, so I bought a new distributor but it is not a genuine one. I bought a Blox TPS, that measures 0.46-4.50v, I'am jumping the timing connector. I can move it advanced, and it does adjust but then the timing marks move further away.
Thanks for reading
Stu
7 years 4 months ago #30997 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Trouble setting base ignition timing
Don't get hung up about the adjustment bolt not being central there is no one correct position for it, years since I did a similar Honda but ISTR that the base timing is set with the IACV disconncted and the service connector jumpered, 700 rpm in which case your ignition timing is spot on.
  • Crombie
7 years 4 months ago #31012 by Crombie
Replied by Crombie on topic Trouble setting base ignition timing
Thanks a lot for the reply, some very good info there and puts my mind more are rest, a couple other things i noticed though is when I start up the car it sits at that slightly advanced position, I must re-do it again when its stone cold just to see, because I thought the PCM retards the timing to warm the car up, so I was expecting to see it bouncing around (whilst the jumper wasn't connected) it was still at the same position, thanks
