2007.5 Silverado 3500 diesel no bulb check
  • keyeswinter
  • keyeswinter's Avatar Topic Author
7 years 4 months ago #30449 by keyeswinter
2007.5 Silverado 3500 diesel no bulb check was created by keyeswinter
I’m having trouble understanding how the bulb check is initiated. I can activate the bulb check with my scanner which leads me to believe the cluster is ok. In the past on other vehiculs I hah put 12 volts on the wire and the cluster has come alive but no joy here. Does anyone know what starts the bulb check
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
7 years 4 months ago #30457 by cheryl hartkorn
Replied by cheryl hartkorn on topic 2007.5 Silverado 3500 diesel no bulb check
what are you asking? the dash lights dont come on when turning the key to run??
  • keyeswinter
7 years 4 months ago #30463 by keyeswinter
Replied by keyeswinter on topic 2007.5 Silverado 3500 diesel no bulb check
Yes check engine is active but abs, brake etc does not
  • cheryl hartkorn
7 years 4 months ago #30492 by cheryl hartkorn
if you can post a wiring diagram i can help you check somethings. its almost like an iginition switch accessory position isnt working
  • keyeswinter
7 years 4 months ago #30534 by keyeswinter
Cheryl
I have enclosed the wireing diagram and bulb check pics both with key and from the scanner hope this helps
I took voltage measurements in both states and couldn’t see any changes
Thanks
  • cheryl hartkorn
7 years 4 months ago #30551 by cheryl hartkorn
so the pictures with all dash light on is using scanner to command them on? 2nd with only checkengine light is using key?? also you getting any codes on a network scan?? can you zoom in on the wiring diagram? im wanting to check power/grounds when it acts up also data lines.
