04 volkswagen beetle 1.8 turbo rough idle
- overdrive138
7 years 4 months ago - 7 years 4 months ago #30138
by overdrive138
04 volkswagen beetle 1.8 turbo rough idle was created by overdrive138
I have a rough running misfiring vw beetle at idle, it does run smoother at higher rpms. I fixed a few vacuum leaks at the intake tube, checked coils , injectors, fuel pressure , and maf all chk out good. I ran the throttle body reset in my verus also. I also had a boost re circulation code so i back probed both terminals at solenoid and had 12volts on both sides at idle plugged in so it wasnt getting grounded by the pcm. from my understanding of the system in the service manual one side is suppose to be 0v on the control side to pcm and the other is 12v . also when the plug is unplugged the driver/control ground side reads 5 to 6 volts . when i actuate the solenoid threw my verus the solenoid clicks ? any ideas ? lmk thx
Last edit: 7 years 4 months ago by overdrive138.
7 years 4 months ago - 7 years 4 months ago #30146
Replied by Andy.MacFadyen on topic 04 volkswagen beetle 1.8 turbo rough idle
Roughness at low rpm often points to either to an inlet leak or a valve or compression issue. As you seem to covered the inlet side .
.Have you done a compression test ?
Last edit: 7 years 4 months ago by Andy.MacFadyen.
- Landroverman1958
- Thank you received: 17
7 years 4 months ago #30154
by Landroverman1958
Replied by Landroverman1958 on topic 04 volkswagen beetle 1.8 turbo rough idle
As i just replied in other thread,check the crankcase breather,these Cars prone to lean conditions ,difficult to remove oil filler cap,,,,,,
- overdrive138
7 years 4 months ago #30156
by overdrive138
Replied by overdrive138 on topic 04 volkswagen beetle 1.8 turbo rough idle
Havent done any compression tests yet the car cranks over at a steady rhythm doesnt seem to have low compression. I dont own a smoke machine but i have been spraying carb cleaner to find leak. I'll be cleaning the throttle body next . U guys have any ideas on the 6v found on the control wire from pcm ? Thx
