Absolute throttle position reading is erratic
- csipes1983..
- Thank you received: 6
7 years 5 months ago - 7 years 5 months ago #29910
by csipes1983..
Absolute throttle position reading is erratic was created by csipes1983..
-1996 GMC Savana 1500 5.9l
-No DTCs
-Slightly high idle 1100 RPM
-Scan tool reading for absolute throttle position bounces around erratically from 0% to 9% with Engine running and at idle.
-Used voltmeter to confirm 5v reference signal (key on engine off)
-Confirmed 1v Throttle position at closed throttle, with smooth transition up to 5v at WOT (key on engine off)
-TPS is new, I put one on after a garage recommended it last month.
Any thoughts on this? Seems TPS is good and sending proper signal to PCM, but PCM is interpreting incorrectly. Maybe PCM grounding issue with engine running?
-No DTCs
Last edit: 7 years 5 months ago by csipes1983... Reason: Need to add detail
- PDM
- Thank you received: 56
7 years 5 months ago #29912
by PDM
Replied by PDM on topic Re:Absolute throttle position reading is erratic
Am I mistaken or is 1.0v too high for idle?
- csipes1983..
7 years 5 months ago #29913
by csipes1983..
Replied by csipes1983.. on topic Re:Absolute throttle position reading is erratic
From what I have read it goes from 1-5 or so. Note: my multimeter doesn’t read decimals. It only reads whole numbers. So it might be less than 1 volt but over .5 volt. Yeah I need a better one.
- PDM
7 years 5 months ago #29915
by PDM
Ok.
10% change will not show up as a whole number. I bet you will see it on a millivolt scale
- csipes1983..
7 years 5 months ago #29916
by csipes1983..
Well the percentage is what my scan tool reads, and it is very erratic, never staying at a consistent percent reading for more than a second. That’s not normal.
- eliteautosolution
- Thank you received: 9
7 years 5 months ago #29924
by eliteautosolution
Replied by eliteautosolution on topic Re:Absolute throttle position reading is erratic
The PCM will idle the engine at a normal speed when the TPS voltage returns to the learned base idle value. This is also called 0% throttle angle. If this throttle angle is 1% or more at idle, the PCM will assume the engine is actually off idle and raise the engine speed to prevent a decel stall. Note that another sensor using the same 5 volt reference as the TPS can momentarily glitch the reference voltage low. This will cause the TPS to send a lower base idle voltage to the PCM, which the PCM quickly records as the new learned base idle voltage. When the reference voltage returns to 5 volts, the base TPS signal voltage increases to it's previous value. The PCM now interprets this as being off idle. This will cause the throttle angle to increase to 1% (or more) and idle the engine at a fast speed. This "glitch" can occur very quickly and may not be visible on a scan tool. IF you can, try to use a pico or similar tool.
- csipes1983..
7 years 5 months ago #29939
by csipes1983..
So an oscilloscope would allow me to confirm the irregular 5v reference signal? How Would I determine what is causing the glitch? Start unplugging sensors?
Thanks
Thanks
- eliteautosolution
7 years 5 months ago #29940
Yes a scope will confirm and pull a schematic and see what shares 5v ref with the TPS. If there is a glitch, unplugging the sensors will help you narrow down to the problematic sensor
The following user(s) said Thank You: csipes1983.., aboudi.naddaf
- csipes1983..
7 years 5 months ago #29960
by csipes1983..
Do you have a good source for vehicle specific schematics?
