05 Astro van intermittent crank no start
  • TonioMartinez
  • TonioMartinez's Avatar Topic Author
7 years 5 months ago #29879 by TonioMartinez
05 Astro van intermittent crank no start was created by TonioMartinez
Hello I’ve been having this 2005 Astro 4.3 intermiten no starts for about 6 months. The van starts and runs great for a month or so and then it just cranks. I notice if I step on the gas pedal repeatedly wile cranking it starts. My fuel pressure is 52 psi with 60 psi prime, and pressure doesn’t drop with engine off. Fuel injector balance test showed equal drop from 52 to 20 on all 6 injectors. I have great spark at the main coil, a little weak spark out the distributor but I consider it good enough. I cleaned the throttle body. Im not liking the fact that i have steady 5 in of vacuum during crank, acceleration, and engine running. Also I have (-) numbers on my fuel trims. And no codes, I have a premium subscription with you, got your book all highlighted and been following your stile for about a 7months rigorously. I purchased a uscope but I’m still having trouble using it. My toughts are I have a bad fuel pump, a bad cap and rotor, a timing issue (distributor related) a bad iac or a bad throttle body. I don’t wanna be a parts Chang monkey (PCM) are there any tips you can share with me based on your experience with Gm
7 years 5 months ago #29880 by PDM
If opening the throttle makes it start, I would look at IAC and TPS data. Log it when it starts properly and see what changes when it doesn't start.
  • TonioMartinez
7 years 5 months ago #29882 by TonioMartinez
Replied by TonioMartinez on topic 05 Astro van intermittent crank no start
Thanks PDM I will compare the readings thanks for your input
