2008 f150 4.2 overheating when ac is on
  • romeo.resendiz
  • romeo.resendiz's Avatar Topic Author
7 years 5 months ago - 7 years 5 months ago #29856 by romeo.resendiz
2008 f150 4.2 overheating when ac is on was created by romeo.resendiz
Does any one have any Idea
What can be happen to this truck it works fine if AC is off
It runs under 230 degrees normal temp.
But at soon as the AC is turn on temp start to to rise really quickly almost as if the compressor was causing it with it's over load
I
Haven't replace any parts so far
Thanks ? to any in advance ?
Last edit: 7 years 5 months ago by romeo.resendiz. Reason: Miss spell
7 years 5 months ago - 7 years 5 months ago #29865 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 2008 f150 4.2 overnight when ac is on
Is the radiator cooling fan switching on as it should just after the AC is turned on ?
Last edit: 7 years 5 months ago by Andy.MacFadyen.
  • romeo.resendiz
7 years 5 months ago #29886 by romeo.resendiz
Replied by romeo.resendiz on topic 2008 f150 4.2 overnight when ac is on
Well the fan is not electric.
And so far clutch seems to work just fine.
7 years 5 months ago #29887 by PDM
Replied by PDM on topic 2008 f150 4.2 overnight when ac is on
Does the temp go back down if you get on the highway?
  • romeo.resendiz
7 years 5 months ago #29896 by romeo.resendiz
No actually the highest the speed the hottest it will get
It does not overheat when Park
7 years 5 months ago #29911 by PDM
Agreed. Look around and make sure nothing is blocking the radiator or stuck in the fins. Then, turn the heat on full blast and see if the temp goes down. If it does, I would put a thermostat in it.
  • romeo.resendiz
7 years 5 months ago #29931 by romeo.resendiz
Replied by romeo.resendiz on topic Re:2008 f150 4.2 overheating when ac is on
Ok thanks I'll do as you said tomorrow I will be doing some updates here as well
Thanks
  • romeo.resendiz
7 years 4 months ago #30232 by romeo.resendiz
Sorry it take so long
But finally got it fixed
Costumer brought it back I checked everything all the way around,
Removed the thermostat it did not work out it overheat even more and quickly
Check at pump it was fine
I decided to replace the radiator and att a new thermostat.
It worked out perfectly fine
I guess even though the radiator was looking good out side there was a problem inside of it.
Thanks guys you saved me from having to tell this costumer to go somewhere else because I have no idea what the problem was and also he save a ton of money by doing it this way
7 years 4 months ago #30238 by Noah
Glad you got it worked out, thanks for the update
