2014 Vw Passat 2.0l TDI crank no start
- Rory67
Ecu requested and actual are good. High pressure actual fluctuates between 4200 and 4700 psi during cranking.
Ecu is not firing injectors verified by low amp clamp around injector solenoid wire.
High pressure fuel sensor on end of common rail has 1.02 to 1.18 volts back probed at sensor signal wire on my Vantage ultra scope. Waveform looks like saw tooth pattern which agrees with pressure readings the Ecu is reporting on data pids.
No codes after cranking.
I don't know enough about these to be any help. I can post diagrams, if it would be helpful.
Here is the best I have to offer:
www.youtube.com/results?search_query=pos...agnostics+passat+tdi
- ScannerDanner
- Administrator
- Thank you received: 500
Don't be a parts changer!
- twolfe89
- twolfe89
- cheryl hartkorn
- Thank you received: 130
- Rory67
Ecu has injector control, on power and ground side (currant limited 50 volt system).
Checked timing last night pinned cam pump and crank all good. Found a cam and crank waveform it checked out good. High pressure side of system is above Ecu requested. Removed egr pipe from side of head to intake verified egr valve is closed cranked with egr pipe off cranked a little faster but no start. Checked for codes after that and got a p0473 exhaust back pressure circuit fault, that sounds like a sensor problem but I'm going down the plugged exhaust rabbit hole tomorrow. Thx for the input Mr wolf anything else would be appreciated. This thing is kicking my ass off and on for the past 6 days
- Rory67
- cheryl hartkorn
- Rory67
- Rory67
If I unplug the throttle valve the Ecu still has injector control (firing) not a very good run away Strategery by Volks Wagon.
So onto the intake side checked data pids for MAF sensor data is all over the place.
Frequency is 22hz KOEO no where near the 800hz expected. Another mechanic friend in the area his daughter has a 2015 Passat 2.0 tdi I hope the maf is the same so we can swap a known good part. Unplugged maf still crank no start I guess no maf sensor failure strategy built into ECU maybe.
- Rory67
When cranking the pid displays a negative number like -.98 or -1.0 on my Verus,, Autel, snap onApollos, and BlueDriver. That doesn't look right to me. Seems it should be 2-4 degrees. When cranking has very little vacuum on a gauge. I covered the intake with my hand while I someone crank it and it will pull a over 20". So it has to be moving air. I get this 20hrz 4.87-.1 volt square wave on the 2 MAF sensor signal wires when the sensor sits overnight and I check it the morning the MAF signal wire shows 1.2khrz at KOEO air temp has a 20hrz signal. After trying to start I come back to the scope and both signal wires have the same 5v ref 20hrz square wave 50% duty cycle. Same shape waveform but go slightly out of time with each other.
Man this car is kicking my ass.
- Rory67
- juergen.scholl
- Active partschanger
- Thank you received: 462
- Rory67
- juergen.scholl
AC-couple the signal from the rail pressure sensor and you will get a recognizable pattern on your scope if the injectors are opening and a pressure drop is taking place. You can check on the 2015 model as reference if in doubt about the signature.
- Rory67
- Desmond6004
Most vehicles work like that but as a word of caution I almost got caught out doing the same thing with a 2017 Holden Colorado. It turned out that the 2005 model could run with a bad MAF sensor but the 2017 doesn't even have the ability to report a bad MAF sensor. On top of that the ECU produced a 'built in' 2 g/s when the vehicle was cranked. After blowing air through the MAF sensor live data showed nothing so I replaced it and the problem was fixed. This was after another company had spent $2000 on it. - as a side noteRory67 wrote: My friend installed the MAF sensor from this car to his daughters car her and her car runs. Unplugged MAF on her car and it will start up and drive around. It's a 2015 Passat tdi 2.0 so that Ecu has a strategy to run with the MAF down..
- Rory67
- Desmond6004
It's actually a 2017 that can't throw a code while a 2005 can.Rory67 wrote: Funny that say that the 2015 could care less if the MAF is plugged in or not it will not throw a code. But the 2014 will code if you unplug it but does not when the data is askew. The MAF seems to function when cold soaked over night. I have KOEO and blown through it with compressed air put it back inline and cranked the engine still no start. Then the signal goes bad after 3-4 minutes of key on. I moved it outside I had to get back on some paying work. It's been ac week here in north west Arkansas.
If the MAF sensor is unplugged it only throws a code for air temp sensor, not for MAF sensor which is weird for a newer vehicle. Almost every other vehicle lets the vehicle start with MAF sensor unplugged - not so with the 2017 which is a reminder to never judge the behaviour of one ECU compared to another model, though we can 'guess' based on statistical possibilities based on averages - but never trust it totally.
