Any fuel injector cleaners that really work?
  • JeffBirt
  • JeffBirt's Avatar Topic Author
9 years 10 months ago #3767 by JeffBirt
I know there are professional systems where you hook a can of 'stuff' to the fuel rail (after disabling fuel pump) and you run the engine on this cleaner until it runs out. From the tests I have seen this really works well. What I'm wondering about is if any of the off the shelf stuff that you pour into the tank actually does anything. Reading a product review is useless as if you spent $15 on a can of wonder cleaner you want to believe it did some good (confirmation bias).
Do you use anything that you think 'really' works?
9 years 10 months ago #3769 by Noah
I've never seen any real positive results from an in tank cleaner. There might be something out there, but I'm doubtful. I don't subscribe to the idea fluid additives.
9 years 10 months ago #3775 by Tyler
I've also never seen any measurable results from an in-tank additive. I have heard that Techron and BG 44K are good, but don't have any personal experience.
  • JeffBirt
9 years 10 months ago #3782 by JeffBirt
Replied by JeffBirt on topic Any fuel injector cleaners that really work?
I guess the 'measurable' part is the real catch. Without pulling the injectors before and after the in tank additive how do you measure the difference? Maybe a pressure drop test? That would only give you a rough idea on flow but the spray pattern might still not be good. I wonder if there has been any real, independent tests on these products?
9 years 10 months ago - 9 years 10 months ago #3785 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Any fuel injector cleaners that really work?
My take on fuel system cleaners is they won't fix anything but with some in the tank there is a detectable difference in the general running of the engine and if you used it from new you would probably reduce the formation deposits on injectors and valves but no way would it make any kind of economic sense.
Oil companies do use similar additives and the fuels sold as super unleaded have more of these additives in them.
Last edit: 9 years 10 months ago by Andy.MacFadyen.
9 years 10 months ago #3790 by Tyler
JeffBirt wrote: I guess the 'measurable' part is the real catch. Without pulling the injectors before and after the in tank additive how do you measure the difference? Maybe a pressure drop test? That would only give you a rough idea on flow but the spray pattern might still not be good. I wonder if there has been any real, independent tests on these products?
Agree 100%, very difficult to measure results for something like this. I'd be good with a injector drop test, but I'd want to know that the injectors had a detectable flow problem in the first place. As for the spray pattern, that might be where a bench tester would come in?
I've always been curious to try an in-tank cleaner on a partially restricted injector, but no customers around here are willing to burn down a tank of gas on a gamble :lol:
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
9 years 10 months ago #3793 by ScannerDanner
Replied by ScannerDanner on topic Any fuel injector cleaners that really work?
BG44k on the Multec 2 injectors that stick closed after sitting.
Don't be a parts changer!
9 years 10 months ago #3969 by WilliamBenz
Replied by WilliamBenz on topic Any fuel injector cleaners that really work?
Does anyone here remove the injectors to clean them?
9 years 10 months ago #3971 by Andy.MacFadyen
You can take them off and reverse flush them using compressed air you need to actuate them while under pressure.
  • johnathon.balderas
  • johnathon.balderas's Avatar
  • Stay humble and thank God everyday for waking up.
9 years 10 months ago #4141 by johnathon.balderas
Replied by johnathon.balderas on topic Any fuel injector cleaners that really work?
I can say first hand that bg fuel injection cleaner does work. We use that in conjunction with 44k and have solved misfire problems doing so.
Time to create page: 0.503 seconds
