02 WRX, Front AFR sensor plugged in = misfires on all cylinders
  • lottadro
  • lottadro's Avatar Topic Author
7 years 5 months ago - 7 years 5 months ago #29237 by lottadro
Hello, this is my first post here. I have been trying to diagnose an issue with my WRX, with front o2 sensor plugged in I have extremely rough idle, misfires on all 4 cylinders, erratic vacuum fluctuation, and hunting AFR. With the front o2 unplugged, no misfires, vacuum stable, though it sits rich at 13. I have removed my rear o2 sensor and installed a AEM UEGO in its place, the DTC has been defeated in tuning with a Cobb Acessport. My tools I have been using are a multimeter, wiring diagram, FSM, and the Accessport where applicable (it allows me to see certain stats from ECM).
I have done a lot of testing between the ECM and front o2 sensor. What I have found is at the pins for the heater circuit ground (D4, D5), the ECM is not commanding them to ground. The FSM calls for a voltage of 0-1.0Vs with Key On Engine Off (KOEO), I am seeing 11.8Vs. I have tested the ECMs grounding pins (D8, D9) and the resistance was fine.
Additionally, I have a thread going on at NASIOC, where a few of us have been trying to come up with an answer, so far we are stumped. I have three o2 sensors I have tried in there, nothing changes, either OEM Subaru or Denso (whom makes the OEM part). I have also tried a spare ECM, and the problem persists. I have cleaned all the engine grounds. I replaced the spark plugs.
Please help me with this, I need this car for longer trips to school I have been fighting this thing since last September. You guys are my last shot.
forums.nasioc.com/forums/showthread.php?t=2900451
ken-gilbert.com/wrx/mans/7%20-%20WIRING.PDF
ken-gilbert.com/wrx/mans/3%20-%20DOHC%20ENGINE.PDF
Last edit: 7 years 5 months ago by lottadro.
7 years 5 months ago - 7 years 5 months ago #29238 by guafa
Hi lottadro,
According to your description, O2 sensor is not getting enough temperature to work properly.
It seems you have a heater driver issue. Have you tried to manually ground heater and see if idle improves?
Last edit: 7 years 5 months ago by guafa.
  • lottadro
7 years 5 months ago - 7 years 5 months ago #29239 by lottadro
Thank you for the reply.
No I have not tried to manually ground. Where would you suggest I add the grounds?
I guess I could back probe a wire directly from the sensor's bulkhead connector, running the wire to chassis ground.
7 years 5 months ago #29240 by guafa
Yes, that could be a good point.
Make completely sure is ground pin where you are. Otherwise if you ground heater power, you will blow a fuse or something else (general speaking).
7 years 5 months ago #29241 by guafa
To be safe, you can add a 10 amp fuse in series.
  • lottadro
7 years 5 months ago - 7 years 5 months ago #29242 by lottadro
Ok, something bizarre happened. I added the ground from the bulkhead connector at the sensor.
I checked voltage on this new ground and it read within spec. .5V.
However, starting the car gave me the p0031 code, heater circuit low. I removed the ground and back probed at ECM connector D4 D5 again, and started car, during operation the pins showed between 7-8Vs. However the idle cleared up, my AFRs were not hunting all over the place. Additionally, a new code appeared p1139, heater circuit not within range. I am not sure what to make of this bizarre situation.
Last edit: 7 years 5 months ago by lottadro. Reason: code correction
7 years 5 months ago #29243 by Tyler
I'm sure you would have said so, but any trouble codes? Not sure how the tuning you've done changes how the ECM sets codes. Do you have any data on what the stock (not the AEM downstream) AFR was doing during the rough idle/low vacuum/misfiring? Guessing very lean, but I think it'd be valuable to know what the ECM was seeing, and it's reaction.
In my experience, when this generation of Suby has a heater fault, it'll code, refuse to energize the heater, and run in open loop. This makes me think that the heater circuit behavior is a symptom of the problem, and not the problem itself. :(
I like guafa's suggestion about manually fielding the stock AFR sensor heater. As an alternative, you can also use the ammeter function in your multimeter to act as both a fused jumper wire AND measure the current of the circuit. I'd expect one amp of current, likely more if the sensor is cold. If you see good current flow, then you know the heater and the wiring is good. ;)
As noted, double check which wire you're grounding. Isolate the ECM if you have any concerns.
  • lottadro
7 years 5 months ago - 7 years 5 months ago #29260 by lottadro
When the o2 is plugged in I get p0301-4 and p0037. Unplugged p0031 & p0037. P0037 pertains to rear sensor, which has been defeated in tune, however will reappear when there are other codes thrown.
Recently when I had that ground manual inserted at front bulkhead connect at AFR sensor, I was getting p1139 and p1130. I went through the diagnostic steps outlined in the FSM for both of those which ended by saying swap out front AFR sensor.
Proceeded to do so, and am back to square one of rough idle and misfiring. Additionally, a torrential down pour started along with thunder. So, today seems to be shot for working on it anymore.
Also I havent had the rear o2 in for a while. The wideband does show swings to lean when it misfires though.
This folder contains both a video and image related to both plugged and unplugged and are labeled accordingly, the image shows the codes I am pulling corresponding to the state of the sensor.
drive.google.com/drive/u/0/folders/1Kkgw...Hgwr_3qSxvY4bXfv0Xdk
7 years 5 months ago #29270 by guafa
Hi lottadro,
At this point o2 heater manually ground, was a test to know if idle and pcm idle control improved (like you said happened). It's not a fixing. I would say those codes could be ignore for a while and stay focus on what Tyler suggested (which takes you to root cause).
Why did you change the first O2 sensor?
7 years 5 months ago #29272 by Tyler
lottadro wrote: Ok, something bizarre happened. I added the ground from the bulkhead connector at the sensor.
Wow, didn't expect that. :ohmy: So as of right now, the mixture is happy and it idles smoothly?
Which connector did you add the ground at, specifically? At the four pin AFR connector? Again, I'd be very interested to measure the current draw of that circuit with your ammeter. I can illustrate this on the wiring diagram if needed. That'll tell us a lot about the wiring integrity under load.
Also, I got to thinking about this:
This seems entirely backwards to me. :silly: AFR heaters are almost never run KOEO, only with the engine running. That means the voltage readings you took are good. I think you're looking at an FSM misprint.
  • lottadro
7 years 5 months ago - 7 years 5 months ago #29275 by lottadro
Quafa, I changed the sensor the first time because forcing the car in to open loop solved the craziness. I made the assumption that it must have been a defective sensor. After replacing it the problem persisted, leading me think it wasnt the sensor, I have been throwing parts at this since last September. I stumbled across Scannerdanner's videos on youtube which got me thinking of testing the wiring. I am definitely a novice when it comes to electronics or wiring, but I've figured out the wiring diagrams and FSM. I switched out the sensor today because new codes p1139 and p1130 popped up after I removed the grounding lead from Pin number 1 on the bulkhead sensor harness, which was throwing a p0031. Those codes remained even after I removed the back probe leading me to believe I had borked the sensor.
Taylor, yeah, I didnt expect that either and was pretty baffled until I assumed that ECM was pushing the car in to open loop, stabilizing the AFRs again. I ground by back-probe at B18, the front bulkhead harness side of the 4 pin sensor connector, Pin 1, which is the negative lead on the heater circuit going to ECM pins D4 D5.
I dont believe I have a good enough DMM for this process of using the ammeter. I'll have to purchase a better one, mine only reads up to 200mA and does not have a 10 amp fuse. If you wouldn't mind illustrating, I'd really appreciate it. Afterwards, I'll run the tests you want with the new DMM when it arrives.
Finally, I believe that the D4 D5 pins should have 0-1.0Vs even at idle, therefore my reading of 7-8vs would still be high, no? If it were a misprint that would seem to invalidate the diagnostic steps for p0031. I'm dont mean to second guess you here, and I hope I am wrong, but it doesnt seem logical to me.
Last edit: 7 years 5 months ago by lottadro. Reason: clarity
7 years 5 months ago #29283 by guafa
Ok, i'm a little bit lost
If idle improved once you manually heated O2 sensor. We assume pcm is in closed loop, can't we?
When you manually grounded o2 heater, you changed current flow passing through heater driver current sensor. That's the reason for those codes. Does it make sense?
I'm trying to give us direction.
7 years 5 months ago #29284 by Tyler
lottadro wrote: I dont believe I have a good enough DMM for this process of using the ammeter. I'll have to purchase a better one, mine only reads up to 200mA and does not have a 10 amp fuse.
Ah, gotcha. ;) If you haven't already ordered one, there's a couple suggestions I could make. The Owon B35T is my personal favorite. 90% of a Fluke meter functionality, awesome durability, fraction of the cost:
www.amazon.com/OWON-Multimeter-Measureme...ording/dp/B01C3IQDE8
The Autel AL539B is also amazing value - scanner, battery tester AND multimeter:
www.amazon.com/Autel-AL539B-Scanner-Star...rging/dp/B079GXRV1M/
Pretty much exactly what you've been doing, except the meter will measure the current draw for you.
Nah don't worry! To clarify, I think you should definitely get some kind of reading lower than B+ at idle, especially with the sensor cold. But with just the key on but the engine not running, a reading of B+ makes sense - to me, anyway. :silly:
Your reading of 7-8V also makes sense to me, as the PCM will pulse width control the heater ground once the sensor is hot and operating. The actual voltage is switching from 0-12V, but the meter averages that out to the 7-8V you saw. That reading makes me more confident in the PCM's ability to control the heater.
For whatever it's worth, I went and dug up some known good data from another '02 WRX that got a Denso AFR sensor due to a failed heater. The data afterwards showed a typical current draw of around 1.7A at idle. That's processed data through the scanner, but still a good point of reference for your testing. ;)
  • lottadro
7 years 5 months ago - 7 years 5 months ago #29287 by lottadro
Tyler and Guafa, I am checking DC10A from the harness pin 1 and am reading around 5 amps at idle. In this set up I am now getting p0032, p0037 (rear removed), and p1130. I dont think with those codes the ECM stays in closed loop. It may manually heat the circuit, but those codes would trip the ECM.
Are you thinking I need a new OEM Subaru sensor?
7 years 5 months ago #29290 by Tyler
Not yet? 5A is awesome current flow, so we know the power side of the circuit is good, and the sensor wiring up to the connector is good.
If possible, redo the same test at the PCM connector itself. Pin D4 or D5. If you get thr same reading, you know the wiring is capable of supporting current flow.
I know you've done resistance testing on these wires, but I really prefer current testing over resistance testing. It's a much more dynamic test that stresses the circuit under working conditions.
If you get a good current reading at the ECM, and the P1130/P1139 remains, I'd suspect an OEM sensor is in order.
  • lottadro
7 years 5 months ago - 7 years 5 months ago #29291 by lottadro
Ok, before I did this test I swapped out the o2 sensor, I have two I have been going back and forth on. One is Denso, the other is OEM. The OEM was the one I had in originally and which I had been doing the tests with. I just switched to the Denso. So, if you want me to return to the OEM one, let me know, I have become a master at switching them out now, can do it in 5 mins without lifting the car.
Just did the same test at D4 D5 at ECM, as well as Pin 1, all were 4.9-5.0 A. The codes I am reading now are p0032 and p0037.
I would like to note that before I do the amp test the car acts in the manner I described previously, rough idle and wacky vacuum. When I connect the leads of the amp tester, I initially read a lower amp around 3ish, it smooths everything out, rises to 5 amp but then pops the codes.
7 years 5 months ago #29294 by guafa
Guys, i'm not completely sure about what we are facing here. Anyway, bear in mind i'm not an expert at subaru.
5 amps reading is happening because you are fully demanding O2 heater. There is not pwm control, neither current pulses.
Again, why is rough idle going away once you heat O2 sensor? I mean, could PCM giving the order to not heat sensor, but at the same time trying to control emissions?
  • lottadro
7 years 5 months ago - 7 years 5 months ago #29299 by lottadro
Guafa, Haha oh no, not you too!
The idle smooths out, wideband shows rich at 13s or so, this may or may not be safe mode engaged by ECM due to the fact that although the sensor is manually ground, it is not seeing the ground signal coming in on D4 D5 from pin 1. Therefore, the computer thinks the sensor is doneso (pun), and safe modes the car; it acts exactly the same if I were to just simply unplug the sensor completely.
Also, a thing to remember, I already tried a spare ECM in there, and that did not fix it. Wires check low for resistance. Power supply is B+ at the power pin (2) and main relay, and SBF-5 fuse. The grounding pins D8 D9 which ground the front and rear sensors check good with low resistance and continuity through the harness all the way to their engine ground on top of the intake manifold.
Its hard to believe both ECMs would have the exact same issue. It is possible, probable, my OEM sensor is borked. It is also possible the Denso, even though they are the producers of the OEM component, is not meeting this specific car's specs and it needs OEM (this has been noted in prior posts on NASIOC). However, I have found nothing that really matches what I am seeing in my case.
Is it also possible, even though from what I can tell from the wiring diagram the o2 sensors are pretty much in their own circuits, that there is another component/ sensor in the engine bay that is causing "noise" within the system? I don't know if that is a good direction to take because it opens the field wide open again. Is the closed loop issue only a symptom of the actual problem?
I really appreciate the both of you taking time to help me with this. Thanks.
7 years 5 months ago #29303 by Tyler
I agree with your thoughts about the heater circuit. I'd like to get it sorted out so the car will allow other codes to set, as something like a heater code will often prevent other codes from popping up. Make sense?
The 13:1 reading in open loop means the car is capable of supplying fuel, which suggests a skewed input. MAF is always a big one, so that'd be my first check.
We know the reading will be all over the place with the rough idle, so how about the g/s reading at hot idle with no electrical loads on in open loop? Also a reading from the MAP sensor KOEO. Should match barometric pressure.
7 years 5 months ago #29304 by guafa
Ok guys, now i'm with you again. I had not noticed AFR when manually grounded. 13:1 AFR is telling us pcm is in open loop.
To Tyler suggestions, i would add a PCM ground test. I know you tested ground resistance, but it's better a voltage drop test. Check voltage between battery (-) and PCM ground when engine running.
Time to create page: 0.474 seconds
