Trying to solve a reduced engine power problem, not sure what to do next
- Giblu427
Giblu427 wrote: and the 5v reference is at 4.26v.
This is where I would be concentrating. Have you checked the voltage at BOTH ends of the wire?
- Giblu427
- Giblu427
Giblu427 wrote: but the black ground wire was solid on 12.2v with my red lead on battery + and black lead at both the wire and on the bolt ( its runs to the back of one of the cylinder heads).
Leave the black test lead connected to Battery (-). Touch the Red test lead to the Black ground wire on pin 15. (Yes, you are testing GROUND-to-GROUND).
A reading of more than 100mv ( 0.1 volt) would indicate a bad ground. Be sure to use the Negative battery post for your black test lead. Not the engine block.
- Giblu427
- Dowachuwant
- Dugy40
Where’s pin 15? Is that on the tps plugin?
- Dugy40
