2011 VW jetta turbo diesel. Flashing glow plug light, DPF light illuminated.
  • kevinedward1234
  • kevinedward1234's Avatar Topic Author
7 years 5 months ago #29175 by kevinedward1234
I have zero knowledge/experience with this VW jetta DPF system, the glow plug light flashes , the DPF light is illuminated on the IPC, not flashing.
Multiple codes in the PCM and they will not clear either koeo or koer. The exaust @ the tail pipe felt like barely any flow. I removed the exhaust from the nox cat back and the flow seemed better, I visually inspected the electric throttle body type motor, it was in the open position. I removed the nox cat and visually inspected the inlet and outlet, no visible signs of a failure, does not mean it is not failed.
Possible DPF filter failure?
At this moment, I do not recall the dtc's in the pcm, vehicle has no power, MAF has 17 plus grams showing on data @ idle, I used the vantage pro and scoped the MAF and it does not respond on a wot, MAF voltage @ idle is around 1 volt, do not recall the exact number.
Any one have experience with VW DPF?
Thanks for any help/ input / direction!
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
7 years 5 months ago #29183 by ScannerDanner
Not much I can offer offhand as my diesel experience in limited to my RV (trial by fire over this past week - video coming) but it would definitely help to know what codes it has in it that will not clear. Then we can research them together.
Don't be a parts changer!
The following user(s) said Thank You: kevinedward1234, aboudi.naddaf
7 years 5 months ago #29208 by Andy.MacFadyen
VW diesels of this era had really serious problems with the DPF not regenerating. This is especially a problem on vehicles that only get urban/suburban use. With a diesel the airflow at idle is should higher than that on gasoline engine. I suspect regeneration will have to be forced or possibly the DPF removed and specialist cleaned off car. I have zero experience of doing this so it might be case of looking for a local DPF vleaning specialist or consulting VW expert.
  • kevinedward1234
7 years 5 months ago #29355 by kevinedward1234
Follow up report, this vehicle is a bank repo, due to many issue's with this vehicle, the bank has decided to take this vw to the auction.
