Ford explorer crank no start
  • A93320336@gmail.com
  • A93320336@gmail.com's Avatar Topic Author
7 years 5 months ago #29162 by A93320336@gmail.com
Ford explorer crank no start was created by A93320336@gmail.com
Good day team
Dear all
I have ford explorer 2002 v6 no fuelflex
It is crank no start i have spark and i didnt check for injector control i check injector have (+)
I spray break cleaner it start
I have no fuel pruesser but i think thy replace fuel pump and make this mistake
Plz find attach and advice it fuel is ok
  • chief eaglebear
  • chief eaglebear's Avatar
7 years 5 months ago #29164 by chief eaglebear
Replied by chief eaglebear on topic Ford explorer crank no start
hi sir I believe that is a bypass ignition some more info would be helpful what is the actual fuel pressure and are there any codes in any of the modules thanks
7 years 5 months ago #29165 by A93320336@gmail.com
Replied by A93320336@gmail.com on topic Ford explorer crank no start
Fuel prusser is 10 psi
No code
7 years 5 months ago - 7 years 5 months ago #29167 by Chad
Replied by Chad on topic Ford explorer crank no start
Amperage is way too low. I suspect you have a voltage drop. Check your fuel pump GROUND and make sure there is less than 100-200 mv. You can, also, check voltage going INTO the pump, while it is running. It should be very close to Battery voltage.
EDIT:
Also, verify that there is fuel in the take. (Don't laugh, I have seen it MANY times.) I calculate the speed to be 6431 RPMs. Low current + High RPM's = no/low fuel.
Last edit: 7 years 5 months ago by Chad.
7 years 5 months ago #29170 by Chad
  • chief eaglebear
7 years 5 months ago #29214 by chief eaglebear
if the pump had bad ground and motor was staining could you hear a difference in pump operation sound
