Burn line
- jerry r
7 years 5 months ago - 7 years 5 months ago #29132
by jerry r
Burn line was created by jerry r
2002 MERCURY VILLAGER 3.3 ,secondary waveform burn line is very high intermittently, feels like it has a slight misfire, what could be the possible causes ? thanks
Last edit: 7 years 5 months ago by jerry r.
- juergen.scholl
- Active partschanger
- Thank you received: 462
7 years 5 months ago #29137
by juergen.scholl
Replied by juergen.scholl on topic Burn time
What is very high, does it affect one cylinder or all? Any turbulance on the spark line?Do you have apicture with the conditions it was taken?
Generally spoken it could be low compression, rich mixture, low secondary resistance........
- jerry r
7 years 5 months ago #29138
by jerry r
Replied by jerry r on topic Burn time
thank you you confirmed what I was thinking
- jerry r
7 years 5 months ago #29140
by jerry r
just one cylinder
7 years 5 months ago - 7 years 5 months ago #29141
Replied by Andy.MacFadyen on topic Burn line
Spark plug worn gap too wide, open in the plug wire and especially if the line slopes upwards lean fuel air ratio
Last edit: 7 years 5 months ago by Andy.MacFadyen.
- jerry r
7 years 5 months ago #29146
by jerry r
Replied by jerry r on topic Burn line
its running a little on the rich side -10 Intermittent at idle
- juergen.scholl
7 years 5 months ago #29150
by juergen.scholl
Replied by juergen.scholl on topic Burn line
I got confused..... When you say burn line is high you actually mean that the burn line starts at a higher kv than normal? Or do you mean the burn time is higher than normal? Please clarify.
- jerry r
7 years 5 months ago #29151
by jerry r
higher then normal
7 years 5 months ago #29155
Normally at idle expect a wide U shape although it will skip around because of the response to the O2 sensor switching.
With a wasted spark system expect lower spark and burn line voltages every other spark. You are best to set a voltage trigger high enough to be triggered only on actual firing events.
- jerry r
7 years 5 months ago - 7 years 5 months ago #29157
by jerry r
I checked the spark plug gap and it was to small , regapped and the high burn line went away, but its still running a little rich,
