2003 hyundai sonata fuel pump relay
- Tsavory
- Thank you received: 2
7 years 5 months ago #29011
by Tsavory
2003 hyundai sonata fuel pump relay was created by Tsavory
Hey guys I have a question about the location of the fuel pump relay in this 03 Sonata. Mitchell1 has it listed in the center console under Radio but i have pulled the cover and don"t see any relays at all. i found the check port next to the OBDII and checked the grey wire which according to the wiring diagrams comes from the fuel pump relay as well neither it nor the fuel pump have power. Hence the reason I need to find this relay
- Tsavory
7 years 5 months ago - 7 years 5 months ago #29024
by Tsavory
Replied by Tsavory on topic 2003 hyundai sonata fuel pump relay
Last edit: 7 years 5 months ago by Tsavory. Reason: added info
- jreardon
- Thank you received: 198
7 years 5 months ago #29026
by jreardon
Replied by jreardon on topic 2003 hyundai sonata fuel pump relay
When i can't find something I just try to look for what it's supposed to look like on rockauto. Maybe someone bolted it somewhere else. 2.4L has metal surface, 2.7L has plastic black cover according to rockauto images. On the 2.4L it's one piece with 8 pins and the fuel pump relay is inside the circuit opening relay I think.
i.imgur.com/Jq5tbds.jpg
The following user(s) said Thank You: Tsavory
- Tsavory
7 years 5 months ago #29032
by Tsavory
Found it and when I grounded the wire coming from the PCM it kicked in the fuel pump but still wont start going to have to go back to the wiring diagram I have to be missing something. Reluctant to call a PCM
- jreardon
7 years 5 months ago - 7 years 5 months ago #29033
by jreardon
Do you have injector pulse? ECM turn on fuel pump relay while engine is cranking or running. Do you have an RPM signal?
edit: I suppose spark is easier to check, so try that.
Last edit: 7 years 5 months ago by jreardon.
- Tsavory
7 years 5 months ago #29038
by Tsavory
I do not have spark Scan tool shows a crank signal but I don't have a scope to verify the integrity.
I also just found out it had a CMP and CKP codes was told it was a p0335 and p0340.
if i am reading the wiring right the CKP is a pull down which gives the ground to power up the FPR. So either bad CKP or PCM?
Would so much easier with a Scope
