2005 Chrysler Town & Country 3.8 P0406 EGR sensor high- follow up
  • Mechanic 350
  • Mechanic 350's Avatar Topic Author
7 years 6 months ago #28850 by Mechanic 350
so Monde, here are the following readings of the wires: KOEO
1. signal wire
plugged = 3.98v
unplugged= 4.94v
2. 5V ref wire
0.01
plugged= 4.98v
unplugged= 4.98v
3. sensor ground
plugged= 0.01
  • Mechanic 350
7 years 6 months ago - 7 years 6 months ago #28851 by Mechanic 350
1. signal wire
plugged = 3.98v
unplugged= 4.94v
2. 5V ref wire
plugged= 4.98v
unplugged= 4.98v
3. sensor ground
plugged= 0.01v
unplugged= 0.01v
4. chassis ground
plugged= 0.00v
unplugged= 0.00v
6. egr control
plugged= 0.00v
unplugged= 0.00v
Can you help me decipher these numbers?
I haven't check ohms yet on the signal wire from solenoid to computer.
thanks
Last edit: 7 years 6 months ago by Mechanic 350.
  • Mechanic 350
7 years 6 months ago #28854 by Mechanic 350
EGR Control Continuity test= good
PCM unplugged:
at 200 ohms= 00.9 ohms
at 2K= .001 ohms
I'm giving you these readings as I'm doing them now.
thanks
  • Mechanic 350
7 years 6 months ago - 7 years 6 months ago #28855 by Mechanic 350
no sir, engine not running. I'm running these tests with the pcm disconnected.
  • Mechanic 350
7 years 6 months ago #28856 by Mechanic 350
I'll run the test now engine running. give me a minute, I have to put pcm and everything back.
  • Mechanic 350
7 years 6 months ago #28857 by Mechanic 350
By the way, short to ground test, checks out ok at OL
meter lead to egr control wire, other lead to battery ground.
  • Mechanic 350
7 years 6 months ago #28858 by Mechanic 350
Any other tests you suggest before I put everything back? thanks
  • Mechanic 350
7 years 6 months ago #28864 by Mechanic 350
ok everything is put back.
  • Mechanic 350
7 years 6 months ago #28872 by Mechanic 350
I haven’t yet. I’m burned out. I’ve been on this car all day. I’ll pick it tomorrow after church. I don’t want to keep you waiting. Thanks for everything. I’ll speak to you tomorrow buddy. Thanks again.
7 years 6 months ago #28890 by Tyler
Still following along when I can. :)
1. signal wire
plugged = 3.98v
unplugged= 4.94v
This value stuck out to me. Does it change with the engine running? I ask because I was recently working on an '06 Caravan 3.8L for various issues, and happened to have a new EGR valve from another shop. The closed valve position voltage was closer to 4.2V.
I don't think that accounts for your code, but it might point towards a faulty potentiometer in the valve.
  • Mechanic 350
7 years 6 months ago - 7 years 6 months ago #28894 by Mechanic 350
The problem is Tyler, that this is the 3rd egr I have replaced
  • Mechanic 350
7 years 6 months ago #28895 by Mechanic 350
No Tyler the engine was not running
  • Mechanic 350
7 years 6 months ago #28897 by Mechanic 350
This link doesn’t open up Monde. It’s says 404 not found
  • Mechanic 350
7 years 6 months ago #28898 by Mechanic 350
Tyler by the way, what’s the procedure for me to test all power and grounds if I ever have to condemn the pcm? Chapter 2 and 3 does not show this. Thanks
  • Mechanic 350
7 years 6 months ago #28899 by Mechanic 350
All the egr purchased thru rockauto.com
7 years 6 months ago #28900 by Tyler
MOROSO321 wrote: No Tyler the engine was not running
Yep, I recall that from one of your earlier threads. Were any of them OEM? Or from the dealer? Because aftermarket EGR valves, especially linear EGR valves like your design, are trash garbage.
  • Mechanic 350
7 years 6 months ago #28901 by Mechanic 350
No, unfortunately, all the valves have been aftermarket.
None from the dealers
All of them non- oem
  • Mechanic 350
7 years 6 months ago #28902 by Mechanic 350
As soon as my wife gets home from church I’ll be able to perform that ohms test that monde told me to do between the 5v ref and the signal wire.
  • Mechanic 350
7 years 6 months ago #28904 by Mechanic 350
  • Mechanic 350
7 years 6 months ago #28908 by Mechanic 350
Connector plugged or unplugged?
Time to create page: 0.355 seconds
