2005 Chrysler Town & Country 3.8 P0406 EGR sensor high- follow up
- Mechanic 350
- Thank you received: 15
1. signal wire
plugged = 3.98v
unplugged= 4.94v
2. 5V ref wire
0.01
plugged= 4.98v
unplugged= 4.98v
3. sensor ground
plugged= 0.01
- Mechanic 350
1. signal wire
plugged = 3.98v
unplugged= 4.94v
2. 5V ref wire
plugged= 4.98v
unplugged= 4.98v
3. sensor ground
plugged= 0.01v
unplugged= 0.01v
4. chassis ground
plugged= 0.00v
unplugged= 0.00v
6. egr control
plugged= 0.00v
unplugged= 0.00v
Can you help me decipher these numbers?
I haven't check ohms yet on the signal wire from solenoid to computer.
thanks
- Mechanic 350
PCM unplugged:
at 200 ohms= 00.9 ohms
at 2K= .001 ohms
I'm giving you these readings as I'm doing them now.
thanks
- Mechanic 350
- Mechanic 350
- Mechanic 350
meter lead to egr control wire, other lead to battery ground.
- Mechanic 350
- Mechanic 350
- Mechanic 350
1. signal wire
plugged = 3.98v
unplugged= 4.94v
This value stuck out to me. Does it change with the engine running? I ask because I was recently working on an '06 Caravan 3.8L for various issues, and happened to have a new EGR valve from another shop. The closed valve position voltage was closer to 4.2V.
I don't think that accounts for your code, but it might point towards a faulty potentiometer in the valve.
- Mechanic 350
- Mechanic 350
- Mechanic 350
- Mechanic 350
- Mechanic 350
MOROSO321 wrote: No Tyler the engine was not running
Yep, I recall that from one of your earlier threads. Were any of them OEM? Or from the dealer? Because aftermarket EGR valves, especially linear EGR valves like your design, are trash garbage.
- Mechanic 350
None from the dealers
All of them non- oem
- Mechanic 350
- Mechanic 350
- Mechanic 350
