2009 Pilot Vibration/Sound
- Tutti57
- Thank you received: 254
Sounds like it is coming from the rear. I crawled under it and didn't see anything obvious. Didn't feel any play on u joints. No torn axle boots or bushings anywhere.
I put the vehicle in the air and had him "drive" it with traction control off and was able to replicate the issue. I couldn't see anything odd happening underneath it but could hear it.
Wheel bearings are ok.
He said that he had some used tires installed last weekend and that's when he noticed it. He said they balanced them.
The rubber around the carrier bearing in the driveshaft is in good shape.
He has sent me a bunch of links to forums of people having issues from the Honda cylinder deactivation set up. Nothing says exactly what the problem with the system is, just that it can lead to worn engine mounts, vibrations, spark plug fouling, and oil consumption.
He has a basic code reader and nothing came up with it.
Any thoughts or info on the vcd topic? I couldn't find any tsbs on it and haven't heard of them causing any problems before now. I would think you'd be able to watch a PID to see if it was activating in relation to the issue but not sure why it would be doing that during acceleration without a code and at set speeds.
What else can he look for?
Thanks!
- Tutti57
I'm thinking that if the problem is happening when it's cold, it can't be the vcd system because it wouldn't be active until the engine is at operating temp.
I'm not super familiar with the system. The
- fudgie
- Thank you received: 4
- Tutti57
He brought it to a shop and they told him the diff is destroyed and the axles were ripped right out of it which sounds like nonsense.
- Tutti57
The fluid change did nothing and I am ruling out the rear end. I initially thought it was the center support bearing but that looks ok.
With it in the air and "driving" I didn't see anything abnormal there or the rear end. The noise that I thought was coming from the back is some exhaust reverb through my scissor lift, I believe.
Found a code for the vrm-4 unit, 77-1, powertrain system failure. Cleared that, drove it, cycled the key a few times and it didn't come back. Mitchel basically says to check rear end fluid and replace control unit if you get that code and that it means the diff experienced a high temp.
The data in the photo looks odd, with target vs actual while accelerating. I'm not sure what to think of that. There was a test in my scantool that checks the right and rear electro magnetic coils and both sides passed.
I found a loose right side inner tie rod but don't think it is related to this. It also doesn't feel like a tire vibration.
I also found that I could active the active motor mounts and that caused some vibration with the KOEO. Not sure if that is normal. It does have 200k+ miles in it.
Drivetrain really isn't my strong point but maybe it will be after this!
- Tutti57
I think this is the place to focus.
Like you saw, the 77-1 code can safely be ignored as long as it doesn't return. The VCM system and the active mounts will usually only show up as a problem on acceleration or light cruise. If the problem is happening cold, then it's also less likely to be something like a TCC shudder.
- Tutti57
It happens regardless of throttle input at those speeds. Decel, cruise, coast, accel.
Tutti57 wrote: The tire rotation did the change anything. Still a vibration at about 20mph and 45mph.
Damn, sorry sir, thought it was worth a try. :silly:
I've seen Honda front CV axles cause vibrations at that speed range, but it's almost always on acceleration only. Never seen a failed rear axle. If it's AWD you can try taking the rear driveshaft out for testing purposes, but I still don't think a drivetrain problem matches your symptoms.
- Tutti57
The problem ended up being a binding u-joint. I didn't end up solving this one but he's a friend of mine so I'm glad it's getting worked out and I did learn a little on it.
Thanks for reading and the replies!
