09 Daihatsu Terios. A/T U540E no reverse
- guafa
- Thank you received: 80
7 years 6 months ago #28683
by guafa
09 Daihatsu Terios. A/T U540E no reverse was created by guafa
Hi everyone,
Do you guys have any experience of reading these solenoids (pintle working) with a scope?
At this point i know one of the hydraulic circuits is delaying 4 seconds to engage its brake (B2).
I completely teared down and cleaned the valve body (same thing after assembly)
Knowing that solenoid is activating on schedule, how do i know if pintle is activating correctly?
Thanks in advance.
Thanks in advance.
7 years 6 months ago - 7 years 6 months ago #28686
Replied by Chad on topic 09 Daihatsu Terios. A/T U540E no reverse
The pintle opening can be seen in the current waveform. RED Trace.
The pintle closing can be seen in the voltage waveform. Blue trace.
Last edit: 7 years 6 months ago by Chad.
- guafa
7 years 6 months ago #28697
by guafa
Replied by guafa on topic 09 Daihatsu Terios. A/T U540E no reverse
Hi pole71,
Oh really? Same as injectors?
Thank you so much.
Thank you so much.
7 years 6 months ago #28700
Replied by Tyler on topic 09 Daihatsu Terios. A/T U540E no reverse
The voltage and current pintle hump method definitely works on transmission solenoids.
The only problem is getting the waveform you want, as some solenoids are PWM controlled. To get a clear waveform, you usually have to control the power/ground yourself (as in, jumper wires).
If you're concerned about delayed engagement, then you might be fighting a pressure leak in the B2 circuit somewhere else in the transmission. Might be useful to watch line pressure while shifting into reverse and see what the pressure does.
- guafa
7 years 6 months ago - 7 years 6 months ago #28704
by guafa
Yes, you are right.
This one is pwm controlled (kind of hard to know how pintle is moving since pintle movement is continous)
About pressure. The gauge showed pressure 4 seconds after you selected "R". I can see that hydraulic delay, but i like to see where exactly leakage is, since history of this transmission tells me that leakage could be in oil pump, valve body, pistons or drains (i mean everywhere). That could be also an actuator still sticking.
Is just a bet to replace the valve body.
Last edit: 7 years 6 months ago by guafa.
7 years 6 months ago #28705
Sounds like some kind of leak, then.
Does SI for this transmission point out any pressure test points with the valve body out?
It used to be that OEs would point out which port did what in the trans, so you could put air pressure to various bands/actuators/whatever and listen for air leaks.
I'm not familiar with this transmission? Just an idea for testing if you're gonna pull the valve body off again.
