2003 Chrysler 3.3 cuts out
- Desmond6004
My diagnosis at the moment is that the ECU must be losing the signal internally (it's filed with gum so can't check for dry joins).
My reasoning is that when it faults the trigger signal for the coil "holds" for a while like some systems do with slow cranking, they hold the spark for a moment to retard timing when the engine is turning really slowly. When it does this the engine dies but the crank sensor signal is still right there at the ECU plug - but it gives a fault for crank sensor signal. Does this sound reasonable?
- Desmond6004
- guafa
- Thank you received: 80
How is supossed camshaft sensor looks like? A single pulse?
Is that engine timing chain, hydraulic tensioner style?
- Desmond6004
I've been told that the CAM sensor was replaced but the old one was refitted after it died again. It could be a faulty sensor
but could also still be buildup of magnetic interference.
- guafa
- Desmond6004
Sometimes the engine just dies, sometimes after it dies the relays click - when the relays click there is this hash on the CAM sensor circuit.
How necessary is the ASD relay? I'm wondering what causes this hash as well.
- Desmond6004
Desmond6004 wrote: How necessary is the ASD relay?
Very. It powers your Ignition Coil and Injectors.
- Desmond6004
But otherwise, does it actually automatically shut the engine down in some situations or is it just badly named?pole71 wrote:
Desmond6004 wrote: does it actually automatically shut the engine down in some situations or is it just badly named?
Given those two choices, my answer is that it is badly named. It is not some automatic safety feature that kicks in. One purpose is to prevent dieseling. When you shut the key off, it kills fuel and spark.
- Paul6004
- Thank you received: 9
