1997 Honda Civic 1.6 surging idle up and down
- Mechanic 350
- Thank you received: 15
- guafa
- Thank you received: 80
You should check for a vacuum leak or any broken hose connected to intake manifold.
- Mechanic 350
- JarheadDiagnostics
- Thank you received: 11
More than just on the throttle body, if you have a smoke machine you can use that for finding vacuum leaks.MOROSO321 wrote: Ok thank you. I will. But this particular throttle body doesn’t have any vacuum hoses. Just two hoses for coolant to run through.
- Mechanic 350
- Mechanic 350
- Mechanic 350
- Mechanic 350
- guafa
That maybe is telling you that when you strangle air intake, A/F ratio is stichiometric or rich. If you check O2 voltage, you could see a rich output.
Do you have additional inputs from engine sensors?
- Mechanic 350
- guafa
It could be posible you are taking ecu to that limit and getting a rich mixture (you can check if so, by checking O2 sensor voltage)
Do you have any other engine inputs for you from a scannerdanner or any app? Those allow you for a better understanding of the issue you are facing
MOROSO321 wrote: Because when I cover the mouth of the tb, the surging stops. So what is that telling me.
I believe that is telling you that you definitely have a vacuum leak. A vacuum leak on a Speed Density Engine will cause a high idle. If the PCM has a rev limiter programmed into it, it will kill the injectors to prevent over revving. When the RPMs lower, the injectors kick back on and the cycle repeats. This is what causes the surging. If you can block the throttle body intake, with your hand, and the engine does not stall, you are receiving PLENTY of air for the engine to run from an UN-authorized source.
I suggest returning to the water bottle, while blocking the Thottle-body intake.
- guafa
- guafa
- Mechanic 350
- Mechanic 350
