Extreme high idle
  • Deltron
  • Deltron's Avatar Topic Author
7 years 6 months ago #28312 by Deltron
Extreme high idle was created by Deltron
Hey guys, got a good one here. One my service advisors has a 2002 saturn sl1 with the 1.9. He's experiencing a super high idle in any gear and it seems to settle down in park. Car will go 30+ mph on its own with no throttle. My "master tech" colleague shotgunned an IAC and that obviously didn't fix it. IAC steps during the problem can reach 120. Car has a -20 STFT and -3 LTFT, single wire O2 reads stoic at this level. Has a single code stored for coolant temp not reaching regulated temp, which it is not. Holding 3k this temp will only hit 160 max both with laser gun and scan data. Pulse width 5ms.
Is the high idle a result of the low temp? That's a dangerous strategy if so. Hard to believe it would allow trim correction of an intentional richening.
7 years 6 months ago - 7 years 6 months ago #28314 by guafa
Replied by guafa on topic Extreme high idle
Hi Deltron.
Is the system jumping to closed loop?
What is telling you MAP/MAF?
Last edit: 7 years 6 months ago by guafa.
  • Deltron
7 years 6 months ago - 7 years 6 months ago #28315 by Deltron
Replied by Deltron on topic Extreme high idle
Yes, it's reaching closed loop. Map activity is normal, no MAF.
Last edit: 7 years 6 months ago by Deltron.
7 years 6 months ago #28326 by Matts Auto
Replied by Matts Auto on topic Extreme high idle
I've encountered a number of vehicles with high idle from low coolant level or stuck open thermostat so I would say yes a low coolant temp could cause an idle issue
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
7 years 6 months ago #28328 by ScannerDanner
Replied by ScannerDanner on topic Extreme high idle
You said IAC counts are at 120 during the high idle? This means the PCM is commanding it and you most likely have an input issue.
Please report TPS readings KOEO and the running at idle.
It would be nice to have voltage and percentage numbers if possible.
Then look at you park/neutral switch, AC command and power steering psi inputs.
Also, what are your ECT readings compared to actual temp? Maybe you said that.
I'm not worried about the low temp, that's not causing your issue, you need a thermostat but I am worried about an inaccurate ECT, these are know for that.
Don't be a parts changer!
  • Deltron
7 years 6 months ago #28595 by Deltron
Quick update, apparently on my day off after I posted this he decided to put a new PCV valve in, and according to him that fixed the problem.
Time to create page: 0.381 seconds
