O2's reading lean. Wiring problem?
- ScannerDanner
- Administrator
- Thank you received: 500
Don't be a parts changer!
- ajherrera58
First I just want to say you and your channel are amazing, but I did just redo the test. The max I was able to read was 89% load. But one thing I did notice however is that when engine braking down a hill my O2 voltages were lower than usual at ~.05 v but I was able to bump them up to ~.35 v by just tapping the gas. I'm not sure if this helps with anything but just something I noticed.
- ScannerDanner
- Administrator
ajherrera58 wrote: @ScannerDanner
This is just a deceleration fuel cut strategy. Injectors are actually turned off during this period which is why your O2s drop so lean.
Thanks!
ajherrera58 wrote: The max I was able to read was 89% load.
Nice.
I was gonna suggest redoing your fuel pressure test with a new gauge, but then I went back and read this:
At idle my engine does bounce the revs, with it being the worst at startup or when just stopped at a light, the car will pretty much stall and bring itself back to life.
I know you already smoked this engine, but this screams vacuum leak.
There's a crankcase breather hose on the front side of the engine block, covered by the intake, that rots through and collapses regularly. Should have showed up on the smoke test, but may have been obscured by the intake. It might be worth doing a visual on this hose before investing more time in a fuel pressure test.
- ajherrera58
Thanks a lot I'll definitely have to re-smoke when I get back home, and I'll try to get a look at that hose. I've tried before but wasn't able to spot it. If I find anything I'll be sure to post.
