2006 Dodge Truck 1500 AC leak
- PatrickT2
- Thank you received: 2
7 years 7 months ago #28065
by PatrickT2
2006 Dodge Truck 1500 AC leak was created by PatrickT2
I have a 2006 Dodge 1500 truck with a refrigerant leak. Here's what I've done so far to find the leak.
I tried the compressed air and soapy water test. There were no bubbles when I sprayed all under hood components with the soapy water.
Next I tried adding a dye to the system. Again, so sign of a leak in the under hood components. There was also no sign of dye in the evaporator drain.
Next I used a Robinair sensor that could detect leaking refrigerant. It did detect a leak in the area around the accumulator. I replaced the accumulator which came with new seals. I pulled a vacuum on the system and within one hour the gauges had returned to zero.
Then I decided to replace all of the seals in the system. This didn't really have a noticeable impact on the system's ability to hold a vacuum.
Next I'm considering trying to isolate different areas of the system to see which area can hold a vacuum and which can't.
Please let me know if you have any testing ideas to isolate the leak.
7 years 7 months ago #28067
Replied by Noah on topic 2006 Dodge Truck 1500 AC leak
It sounds like you've been very thorough in your testing. Most of the significant leaks I see are at the bottom of the AC condenser where road debris gets kicked up. The last real tricky one I found I needed an inspection camera to spot the leak with soapy water.
Also worth noting to check your equipment. I've gone looking for leaks that weren't there because the gauges/lines were allowing vacuum to escape over time, not the a/c system.
Good luck, stick with it!
7 years 7 months ago #28081
Replied by Tyler on topic 2006 Dodge Truck 1500 AC leak
I second Noah's recommendations. The only other thing I'd suggest is charging the system and checking the evaporator drain for dye/refrigerant. Leaking evaporators aren't super common on these trucks, but not unheard of.
One way to verify this would be to take both evaporator lines loose, plug one, and install a hand vacuum pump on the other. If you've got your connections tight, then a leak will be obvious. Do the same with pressure.
- fahead32
- Thank you received: 3
7 years 7 months ago #28082
by fahead32
Replied by fahead32 on topic 2006 Dodge Truck 1500 AC leak
Any sign of oil stains also check rear seals on compressor
