misfire cylinder1
  • thechad33
  • thechad33's Avatar Topic Author
7 years 7 months ago - 7 years 7 months ago #28060 by thechad33
misfire cylinder1 was created by thechad33
alfa romeo 156 2003 2.0l JTS
first thing in moring mis fire for 5 minutes then doesnt miss a beat all day
#drop test and coil swap no change
#swaped 1 and 2 injectors no change
# have good powers and grounds
im lost i need help with new direction be fore i swap out a computer i want to find the fix first
Last edit: 7 years 7 months ago by thechad33.
7 years 7 months ago #28068 by Noah
Replied by Noah on topic misfire cylinder1
I'm unfamiliar with that engine, but a cold start misfire can be a sign of a failing head gasket.
How is the coolant level? Are you needing to top it off every so often?
I don't know if it's pheasable on this engine, but you could pull the #1 spark plugs in the morning before starting it up and look into the cylinder with a boroscope (or maybe just a flashlight) and look for wetness from coolant.
Also, a chemical test of the coolant system should reveal that particular failure should it be present.
