2013 nissan versa sv fuse 49 blows intermittently
  • cheryl hartkorn
  • cheryl hartkorn's Avatar Topic Author
7 years 7 months ago #27749 by cheryl hartkorn
2013 nissan versa sv fuse 49 blows intermittently was created by cheryl hartkorn
having an issue here. came to as a no crank and can bus codes. found fuse for tcm blown. can talk to it now. fuse pops intermittently when going into reverse. when i could get it to act up where itd happen all the time i unplugged the trans range sensor and fuse stopped blowing. so i put in new sensor 4 days later doing it again. this time i cut the orange wire at pin 5 going to the reverse lights lasted 6 days. anybody seen this before. i might unplug every thing on that circuit and checkfor a short to ground. next time it happens i want to unplug the connector at the transmission solenoids see if the short goes away when its acting up
7 years 7 months ago - 7 years 7 months ago #27754 by wacoeagle
do u have a wiring diagram u can post
Last edit: 7 years 7 months ago by wacoeagle.
7 years 7 months ago #27755 by wacoeagle
have u checked wires going to park position switch
www.bbbind.com/tsb-wiring-diagrams-datab...em=169&docid=8161677
  • cheryl hartkorn
7 years 7 months ago #27759 by cheryl hartkorn
Replied by cheryl hartkorn on topic 2013 nissan versa sv fuse 49 blows intermittently
think thats for the manual trans
7 years 7 months ago #27766 by wacoeagle
I wonder if the shifter being movedhas anything to do with it, like theres wires being pinched somewhere. if its blowing a fuse, its either a circuit overload by excessive amp draw or a direct short. you need to identify ALL wires in the circuit and physically trace them down.
7 years 7 months ago - 7 years 7 months ago #27767 by wacoeagle
www.bbbind.com/tsb-wiring-diagrams-datab...tem=10&docid=6681481
I wonder if you have water getting into the tailights and blowing the fuse.
  • cheryl hartkorn
7 years 7 months ago #27771 by cheryl hartkorn
checked those. even drove with both tail lights removed.
7 years 7 months ago #27782 by wacoeagle
sounds like you wiill have to start at the fuse, and find every wire that is on that circuit. draw with a highlighter on the wiring diagram.check each one for short to ground . it sounds like theres a wire rubbing to a ground somewhere. does it happen more when its damp outside or on bumpy roads?
7 years 7 months ago #27783 by wacoeagle
this is a heck of alot of stuff on a 10 amp circuit, looks like an engineering snafu..
49 10 Back-Up Lamp, BCM (Body Control Module), CVT Control System, Engine Control System, Intelligent Key System/Engine Start Function, NVIS, Power Distribution System, Navigation System, Starting System
7 years 7 months ago #27784 by wacoeagle
if every different system on that circuit were fused, you could see exactly where its happening ... . exactly what codes was it throwing,? what numbers.
what scanner are you using, can u access event data?
  • cheryl hartkorn
7 years 7 months ago #27785 by cheryl hartkorn
not throwing any codes. it just loses communication with the tcm then the gear shifter indicator disapears on the dash. when shut off it becomes a no crank. it hasnt blown this week yet.
7 years 7 months ago #27792 by wacoeagle
Was the part u replaced OEM? been hearing of alot of issues with electrical parts in the aftermarket not cutting the mustard. with a circuit that stacked, in sure there isnt much room for variances.
I dont understand how they can have the starter and transmission, on a 10 amp fuse, along with everything else. have u found where this circuit grounds? I believe a poor ground can cause an amperage spike
7 years 7 months ago #27917 by Paul6004
Water can't make anything short out! (it can cause corrosion however but certainly can't make a short)
Try fitting a "short light". Remove the fuse and wire up a headlight bulb bright beam circuit to it (the two furthest apart on the bulb), insert a wire in each side of the fuse holder MAKING SURE THEY CAN'T TOUCH! .
Your bulb becomes your fuse except it doesn't blow, it just goes bright when there is a short. if you're lucky and it stays bright when the short is there (it could go off as everything else loses power) you can trace the current using a clamp meter, or simply go and move things around and unplug things until it goes off - then you have located your short.
