12 Mitsubishi Outlander issue
- fahead32
- Thank you received: 3
7 years 7 months ago #27564
by fahead32
12 Mitsubishi Outlander issue was created by fahead32
I have a project car I got from the auction , a 12 Outlander 2.4 it was damaged in a front on accident and is not starting . I have replaced the Ecu because the temp sensor was reading -40 degs. and there was no power from the computer(check at computer harness) I have programmed the Vin and the Keys to the ECU. So the car would start for two seconds and quit .I have check fuel at the rail also check the injectors for the clicking (one bad) but I figure that would not stop it from running . I would figure that it would run but poorly.
I checked for DTC's but the only code I get is a timeout code for the SRS unit
Any thoughts or suggestions welcomed
- guafa
- Thank you received: 80
7 years 7 months ago #27578
by guafa
Replied by guafa on topic 12 Mitsubishi Outlander issue
I don't know that car, but others which need to be reset after a crash. Maybe a crash switch or acelerometer.
The following user(s) said Thank You: diagDOG
- diagDOG
7 years 7 months ago #27768
by diagDOG
Replied by diagDOG on topic 12 Mitsubishi Outlander issue
The other poster that said check fuel safety cutoff is correct
also if you changed the ECU and get starting for a few seconds can very much be a symptom of ECU/Immobilisr mismatch or Immobiliser no comm
They will often allow a few seconds run..
Are you certain you programmed keys/immobiliser correctly
- fahead32
7 years 7 months ago #27802
by fahead32
Replied by fahead32 on topic 12 Mitsubishi Outlander issue
sorry for the late response , I am sure it was done correctly because it gives a success message and it allows you to program the remote / keyless functions and both were completed . The key count also increases after programming
- Desmond6004
7 years 7 months ago - 7 years 7 months ago #27814
by Desmond6004
Perhaps try disconnecting the SRS unit as a test.
Replied by Desmond6004 on topic 12 Mitsubishi Outlander issue
Question: Since the SRS unit has the ability to tell the ECU to shut down when there is a crash could it actually be the SRS fault making the engine shut down?fahead32 wrote: I checked for DTC's but the only code I get is a timeout code for the SRS unit
Last edit: 7 years 7 months ago by Desmond6004.
