Wrangler tj 2005 not been beaten
- F88ryan88
7 years 8 months ago #27341
by F88ryan88
Wrangler tj 2005 not been beaten was created by F88ryan88
Po340/344/016 codes only show up on code reader after sitting ling enough to get very cold been trying to figure problem for 1 1/2 years atleast now and replaced every sensor did no limp kit in the 42rle tranny and can only comeup with the conclusion (i have a wire in the wiring harness not making contact when its cold out and when it warms up under the hood the wire expands) and makes contact again Since yhe jeep will run perfect if 190 degrees and i clear the fault codes HELP!!!!! please im trying to figure the beat way to test the wiring for this
- F88ryan88
7 years 8 months ago #27342
by F88ryan88
Replied by F88ryan88 on topic Wrangler tj 2005 not been beaten
Picture of engine bay wiring harness around the rear of the valve cover rubs and i did find one wire broken and i have repair it cam and crank corelation issue when cold
- F88ryan88
7 years 8 months ago #27343
by F88ryan88
Wrangler tj 2005 4.0l auto with abs ac cruise control
- F88ryan88
7 years 7 months ago #27350
by F88ryan88
Watched scanner danners video on cam sensors with a wrangler jk 4 door and this should be my fix as well
- F88ryan88
7 years 7 months ago #27599
by F88ryan88
Yes i did while posting my issues lol and problem solved i did danners #1 rule wrong and changed just about everything on the jeep a ended up right back at the cam sensor i had replaced it 3 times with all bad cam sensors from autozone my signal wire would read correctly when the sensor was hot but not when it sat outside for a few hours so i tested the cam sensor when warm good then waited two three hours when temp on engine was cold not signal coming from cam sensor replaced it with one from carquest repeated test same way 100% fixed for past two weeks then checked the two i took off over past year all did excactly same thing autozone junk!!!!!! If id of done this sooner i would have saved money on transmision limp mode kit, all tranny sensors on valve body speed sensors cam sensors crank sensor tranny fluid atf+4 and alot of my time!!!! Luckily it my own personal vehical so chalking it up to lesson learned the hard way and perventive maintance since the 4.0l only has 116,000 miles thank you for responding (Dont buy autozone!!!)
