p1349 vvti solenoid.
  • cyrus.nk
  • cyrus.nk's Avatar Topic Author
9 years 11 months ago #3448 by cyrus.nk
p1349 vvti solenoid. was created by cyrus.nk
How to identity soleniod whether it's groundside controlled or powerside controlled.socket plugg in koeo 12 on both wires this is a groundside controlled.0 volt on both wires koeo powerside controlled.right?now i am confused,have toyota mark 2 1gx with p1349 vvti soleniod.koeo am getting 0volts on the wire wich is supposed to have 12 volt but once i disconnect the soleniod i get 12 volts back and 10 mv on ground control wire.wen i start the engine i get 0volts on 12 volts wire socket plugged in and after like 30 second i get 2 to 7 volts on the same wire.wat cound be happening here ooooo?????
9 years 11 months ago #3458 by matt.white
Replied by matt.white on topic p1349 vvti solenoid.
Does the 12v come from the ecu or from a relay? Is there other components fed from this 12v supply that could be pulling it low?
I guess it's possible the solenoid itself is shorted pulling the 12v low but I thought that would have blown a fuse or something. Can you do a resistance check on the solenoid?
  • cyrus.nk
9 years 11 months ago #3469 by cyrus.nk
Replied by cyrus.nk on topic p1349 vvti solenoid.
Yep resistance 9 ohm.12 volt comes from fuse not pcm.what I have noticed is once the key on position the solenoid is energized.I can here it criking. I get 12 volts on one wire wen i unplug the socket but once i attempt to plugg in 12votlts is pulled down to zero and i hear solenoid opening.
9 years 11 months ago #3470 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic p1349 vvti solenoid.
I don't know the system but could it be duty cycle controlled?
9 years 11 months ago #3473 by matt.white
Surely no matter what you do that 12v supply from the relay should remain constant. What model is this? Car and engine? Can you post a wiring diagram for that component?
Just looking at a Corolla diagram, both wires coke from the ecu so perhaps the 12v you see is just a circuit integrity check. It doesn't seem right if your solenoid activates with just koeo though.
There's also a tsb for p1349 on some toyotas for a failed cam gear.
I'm wondering if this code sets if the cam timing is off too.
  • cyrus.nk
9 years 11 months ago #3474 by cyrus.nk
Yes,it's duty cycle controlled. I can see 90% on ma scantool at idle and 40%at high rpm
  • cyrus.nk
9 years 11 months ago #3475 by cyrus.nk
Am sorry for misleading u guys.both wires comes from pcm
9 years 11 months ago #3477 by matt.white
Ah ok. And the 2 to 7 volts I'm assuming is on a multimeter which is averaging out the pulse width readings?
One thing I have seen is the oil gauze block up. It's normally behind a 17 or 19mm plug in the head. They block up and won't let oil pressure to the solenoid.
What model engine is this?
Here's a link to the tsb I mentioned.
www.toyotaparts.metro-toyota.com/M.I.L._...UATOR_T-EG009-03.pdf
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 11 months ago #3480 by Dylan
Replied by Dylan on topic p1349 vvti solenoid.
Like Matt mentioned, try to be more specific Cyrus. We're here to help but decent feedback is important ;)
A lot of great info has been posted. Our members are awesome!
As for your P1349 it usually ends up in changing the VVT actuator on camshaft. Definitely check filter as mentioned.
Do you have the possibility to perform an actuator test on your scan tool?
  • cyrus.nk
9 years 11 months ago #3495 by cyrus.nk
Ok thanks guys!let try those things first
9 years 10 months ago #3617 by matt.white
How'd you go Cyrus?
  • cyrus.nk
9 years 9 months ago #4252 by cyrus.nk
Am sorry for late reply.It was bad vvti filter.2 to 7 volts which i was getting was pulse from ecu on high control side.
