CO too high on Hyundai, rich condition, failed emissions test.
- McFly1
I have a difficult problem at hand and hope somebody can help me in solving this. After some parts swapping I have bought a Hantek 1008 scope in order to do some more intelligent troubleshooting.
The car: Hyundai Getz 2005 1.1TB 63HP 212000 Km The problem: Emission test failed: CO 0,5%_CO2 15,5%_O2 0,2%_HC 80 @2500 rpm The limit here is 0.2% CO.
The car runs fine, good power, cold start always perfect, doesn't misfire or sputter ever, no engine codes stored. Plugs and wires are new, recently serviced.
I have swapped the MAP sensor, the cat and tried three (used original) pre cat oxygen sensors with no change in the exhaust gas analysis or driveability. Car keeps having CO around 0,5% @ 2500rpm and what seems a rich condition. Through all of this the car operates fine.
After removing the ECU I tested the wiring from pre cat O2 to the ECU and all is fine, no short to ground or connection between the 4 cables.
Now with the Hantek scope I have plotted the pre and post cat sensor. Pre cat sensor at idle has 0,3 - 0,6Hz and a range between 0,15 and 0,78V, at 2500 rpm it has 1,8 to 2Hz and ranges between 0,05 and 0,86V. This is a used sensor, it is switching as it should but is it too slow due to age perhaps? Not sure if 2 cycles per second is enough.
Post cat sensor stays on 0,68V at idle and 2500rpm, only when accelerating it drops suddenly to near zero volts and then goes back to 0.68 again. Not sure why it does this.
I don't have a gauge for measuring fuel pressure or a tool to read live ecu data, at this point I am not sure what to test or try next. It might be that the O2 sensor is not quite as good as it should anymore, but next to that something seems to be causing a rich condition so there might be two issues causing the problem?
- chief eaglebear
- Thank you received: 70
- kostelectronics
Further: check the air-filter and the fuel-pressure if it's in range. You can have a leaking injector too (not fully closing).
From where are you?
BR Matthias from switzerland
- McFly1
- McFly1
- McFly1
- McFly1
I swapped the MAP sensor already with no effect on exhaust gas. Currently reads 27 Kpa at idle. Intake and cooling temp values are normal and rise gradually to operating temperature. Any fuel flow issues would cause lean condition or engine stutter? Engine is rich and runs like clockwork. When I took off the exhaust manifold everything was covered in black soot, cylinderhead ports, manifold pre and post cat and also the exhaust tip so it's been burning too much fuel for a while.
Had one strange occurance today when measuring; when the engine was hot and idling the fan came on, and immediately the post cat O2 sensor dove to less than one volt. It remained there until it turned off and then went back to 0,7V. The fan came on several times after that but then it stayed at 0,7V.
- guafa
- Thank you received: 80
You said pre cat frecuency is 0,3 - 0,6Hz. that means you have a period there like 3 - 1.8 seconds which is low for me. Next week i can check a hyundai getz 1.6 and look for pre cat o2 frecuency.
Do you have good emission readings at idle?
What happend with O2 pre cat sensor voltage when you acelerate? Post cat sensor looks like reflecting a lean condition.
Try to take ECT voltage a little bit down. That simulate a higher coolant temp. than normal and allows PCM to substract a little bit of fuel.
- guafa
chears.
P.S I don't know why my replies are posting eco´s
guafa wrote: P.S I don't know why my replies are posting eco´s
Don't worry, it happens to everyone. :silly: Some kind of bug in the forum.
Are spark plug gaps ok? Past week i fixed a kia soul which according to manual spark gap should be 1.1 mm. I adjusted gap to 1.0 mm and HC decreased from 270 - 70 ppm.
Really? :huh: Were they the correct plugs for the application? I'd love to hear more about what led you to check plug gap.
- guafa
He took the car for emission test and it was rejected. He told me that some hesitation was present also. then I started by changing oil, filters and then a visual inpection of spark plugs. I saw one of the gaps at 1.0 mm and the others at 1.2 - 1.1mm. I cleaned all and adjusted at 1.0mm (which is the same gap of an old car i have). The car stopped hesitation and HC went down.
Again, lucky me. but i have heard some spark plugs which make the engine out of emission ranges (gap, materials, etc).
What took me lots of time (and learning) is an updated i made to an old carburetor car. It´s an old mazda which i adapted a new renault clio injection system. In order to comply with emission test, i had to play around with ECT voltages, sensors, etc.
- guafa
- McFly1
- guafa
Part of the message is hidden for the guests. Please log in or register to see it.
Hi McFly1,
Have you checked oil, Evap system, fuel regulator, injectors?
- McFly1
- guafa
1. Try with a brand new upstream o2 sensor (you have always tried with used ones)
2. Change ECT sensor (this according to my own experiments, affects so much emissions).
3. Connect a potenciometer in series with ECT and play until get correct CO levels (so that i can discard mechanical issues (for instance vacuum leakage or bad head gasket))
- guafa
- guafa
Have you checked any carbon deposits inside chambers?
- McFly1
