Coolant in Engine Oil
- Bobby10
- Thank you received: 2
7 years 8 months ago #27069
by Bobby10
Coolant in Engine Oil was created by Bobby10
Coolant in Engine Oil.
Engine block and cylinder head resurfaced 3 months ago.
New head gasket.
Any suggestion?
New head gasket.
Any suggestion?
- chief eaglebear
- Thank you received: 70
7 years 8 months ago #27070
by chief eaglebear
Replied by chief eaglebear on topic Coolant in Engine Oil
is the oil in the coolant or is the coolant in the oil no just kidding lol maybe try a coolant pressure test it will force it out one thing to keep in mind is gasket can fail between cylinders but then you would probably see a lot of white smoke and smell coolant there are dyes you can add to coolant and or oil
- chief eaglebear
7 years 8 months ago #27071
by chief eaglebear
there are videos online on how tom pull codes on that it will give a little direction
- Bobby10
7 years 8 months ago #27072
by Bobby10
Replied by Bobby10 on topic Coolant in Engine Oil
The head gasket is only 3 months "old".
I will put pressure in the coolant system and I will also check for HC.
But if it is not a head gasket, the only last options are crack in block or head?
- Matts Auto
- Thank you received: 28
7 years 8 months ago #27075
by Matts Auto
Replied by Matts Auto on topic Coolant in Engine Oil
Can you post vehicle information could be intake gasket leak as well if it's a V motor
- Bobby10
7 years 8 months ago #27079
by Bobby10
Nissan X-Trail T30 2lt Petrol
- Matts Auto
7 years 8 months ago #27083
by Matts Auto
misfire on initial start up would be indicative of cylinder head leak. I would recommend warming engine then pressuring coolant system for about an hour then remove spark plugs and check cylinders for presence of coolant. Also are you seeing coolant in the engine oil or are you seeing oil in cooling system ? I ask because Nissan has had many transmission cooler issues mixing transmission oil and coolant .
7 years 8 months ago - 7 years 8 months ago #27084
Replied by Andy.MacFadyen on topic Coolant in Engine Oil
All of the above --- additionally although less common than it used to be water (nb not coolant) in the oil can be a sign of the engine not getting up to a high enough temperature to drive off water from combustion.
Head gaskets and fail in a number of different ways, with the case of coolant going into the oil the header tank gas test may not give a positive result and there is no absolute way to tell an inlet leak from a head gasket leak .
Last edit: 7 years 8 months ago by Andy.MacFadyen.
Time to create page: 0.365 seconds
