2007 Dodge Nitro electrical issue
- TOMMITYTOMTOM
- cheryl hartkorn
- Thank you received: 130
- cheryl hartkorn
- TOMMITYTOMTOM
- TOMMITYTOMTOM
- TOMMITYTOMTOM
TOMMITYTOMTOM wrote: Hi, M15, M16 and M33 have no voltage with key on. thoughts ?
How about M37? Because according to the diagram, M15, M16, M33 and M37 all get power from the Run/Start relay (likely integrated into the TIPM).
M15, M16 and M33 power other accessories, but M37 goes to the PCM. That'd very neatly explain your lack of communication.
- TOMMITYTOMTOM
- cheryl hartkorn
cheryl hartkorn wrote: post the diagramif you could
The entire power distribution diagram is too big for the forums.
I have the wiring diagram but it's a bit overwhelming.
Not your fault - it's a big diagram. :lol: And the relationship between the four fuses isn't very clearly indicated.
- wacoeagle
- Thank you received: 37
what was smoking was it the winding inside the alternator? the wiring going to the alternator? start backtracking from the alternator back. is the alternator fused with a fusible link? did it short out the battery? did it burn ground lugs off of anything? smoking usually means DIRECT SHORT!
- TOMMITYTOMTOM
TOMMITYTOMTOM wrote: Car wasn't jumped off. She noticed smoking and sent me a small video. Lucky for me that she knows her way around my tool box and I had her disconnect the battery quickly. The smoke was from inside the alternator case. I've verified all user-replacable fuses and relays in the TIPM are good. Fuses were checked with a meter for continuity when removed from TIPM. Relays, the same way but with a 12V power supply to check coils in relay and DVM for continuity as well. I may take the TIPM apart again and check the small relays as well. There isn't a fuseable link anywhere that I can find.
Do you recall if fuse M37 had power KOEO?
- TOMMITYTOMTOM
- TOMMITYTOMTOM
TOMMITYTOMTOM wrote: Sorry for the delay, I've been in the hospital. M37 is ABS/ESP/STP/LP SW/FUEL PUMP RELAY HI CONTROL. No voltage (KOEO)
Sorry to hear that.
Definitely sounds like the Run/Start relay isn't getting energized, OR there's an issue on the load side of the relay.
- TOMMITYTOMTOM
