Rod knock
  • jchristman3@cox.net
  • jchristman3@cox.net's Avatar Topic Author
9 years 11 months ago #3362 by jchristman3@cox.net
Rod knock was created by jchristman3@cox.net
2002 Infinity I35
3.5 liter, V6
3 pin COP
Service Engine Soon light illuminated.
Scanned codes: P0305, cylinder 5 missfire
Freezeframe: Coolant - 195F, Vehicle Speed - 73, RPM - 3849
Start the engine. No discernible missfire.
So I do the cylinder drop test to see if the coil's chooching.
Pull the coil primary connector off.
RPMs drop, but rod knock noise starts. Not click, clack like a lifter.
Clunk, clunk like a wrist pin.
Put the primary back on.... no noise. Smooth. No missfire.
Pull the primary on coil #6. RPMs drop, but no clunk, clunk.
In the old days, shorting out the plug or pulling the wire made the rod noise go away.
Turning the plug off on this guy makes the noise.
I suppose a compression miss is possible if the piston is flopping around changing the compression ration in one hole.
Any ideas?
9 years 11 months ago - 9 years 11 months ago #3376 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Rod knock
Piston Slap ?
Other random ideas not connected to the misfire code --- crank pulley has play on the crankshaft or torque convertor is moving on flywheel drive plate.
Last edit: 9 years 11 months ago by Andy.MacFadyen.
