2008 Range Rover Sport HSE 4.4 Cylinder Misfire on all 8 cylinders P0300 - P0308
- Captaincqb
7 years 8 months ago #26662
by Captaincqb
2008 Range Rover Sport HSE 4.4 Cylinder Misfire on all 8 cylinders P0300 - P0308 was created by Captaincqb
Crank my truck up one cold morning and it went dead. I thought nothing of it crank right back up no problem. Let it warm up and went about my day as I was accelerating I could feel a slight power decrease no matter when I hit the pedal at any speed it would drag a bit. I was thinking maybe its time for tune up so I purchase a scan tool just to see if any codes were stored. There is no check engine light on but when I ran my launch VIII it shows 12 codes. P0301 - P0308 cylinder misfire, P0300 - Random misfire detected, P0316 Misfire detected on startup, P0420 Catalyst system efficiency below threshold bank 1, P0430 Catalyst system efficiency below threshold. Bank 2. I’m by no means a mechanic but can pick up things quickly and have some knowledge with engine. My thought was this is probably a fuel issue causing my misfire issue. I have a fuel diagnostic tool but not sure where to connect on this engine as I can’t fineSchraeder Valve to check fuel pressure. Since the vehicle runs somewhat well could it just be that I need to relplace fuel filter(where is that located)? Just was hoping someone could help in pointing me in the right direction.
- Captaincqb
7 years 8 months ago #26664
by Captaincqb
Replied by Captaincqb on topic 2008 Range Rover Sport HSE 4.4 Cylinder Misfire on all 8 cylinders P0300 - P0308
Do anyone know where I can connect the fuel pressure gauge to test fuel pressure on this vehicle? No valve
- Matts Auto
- Thank you received: 28
7 years 8 months ago #26671
by Matts Auto
Replied by Matts Auto on topic 2008 Range Rover Sport HSE 4.4 Cylinder Misfire on all 8 cylinders P0300 - P0308
Not familiar with that vehicle but if it doesn't have a schraeder valve then you need to tee into the fuel line at filter or rail.
- Captaincqb
7 years 8 months ago #26672
by Captaincqb
Thank you for your response. I’m not sure where the fuel filter is located. I’m guessing it’s in the tank. I do see a rubber hose that connects the two rails so I’m thinking I can Tee into that line.
- Valessilo
- Thank you received: 7
7 years 8 months ago - 7 years 8 months ago #26673
by Valessilo
Replied by Valessilo on topic 2008 Range Rover Sport HSE 4.4 Cylinder Misfire on all 8 cylinders P0300 - P0308
Last edit: 7 years 8 months ago by Valessilo.
- Captaincqb
7 years 8 months ago #26674
by Captaincqb
Very much appreciated. The diagram helps a lot. I don’t have the special adaptor but I think I can figure out something to connect to at least one of those spots in the fuel rail. Just my luck fuel filter is in the tank. Might as well replace both if I have to remove tank to access it.
- Captaincqb
7 years 8 months ago #26680
by Captaincqb
- Valessilo
7 years 8 months ago - 7 years 8 months ago #26681
by Valessilo
www.amazon.com/OTC-7337-Fuel-Line-Disconnect/dp/B0002SRCYW
imgur.com/a/raOauM5
Video on removal:
I'm researching just as you I never see these before.
imgur.com/a/raOauM5
Video on removal:
- Valessilo
7 years 8 months ago - 7 years 8 months ago #26682
by Valessilo
You could probably make a tool yourself... measure diameter, find a pvc pipe that fits and cut like this and reassemble on fuel line lol
imgur.com/a/Cfo6WYc
okay don't cut like that, cut it in half instead to make fitting it on easier
imgur.com/a/Cfo6WYc
- Captaincqb
7 years 8 months ago #26685
by Captaincqb
I have been checking everything on YouTube and did not come up with anything. Thank you for your research. Going to try to go at it tonight.
Time to create page: 0.387 seconds
